Toshiba 50HX81 50" Rear Projection Television Logo
Anonymous Posted on Jun 29, 2010
Hello i have a 50hx81 toshiba television and i'm having problems w/ the screen....it's closing...how can i fix it?
  • Anonymous Jul 01, 2010
    Thank you...I got rid off my tv because it's only taking space in my living room and the screen has completely closed
Anonymous
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 117 Answers
  • Posted on Jun 30, 2010
Anonymous
Expert
Level 2:
Mentor:
Answers
117
Questions
0
Helped
24146
Points
174
Well if its close down in size you have a vert, problem
Trying to locate a power button for Toshiba 50HX81 50 in. Rear Projection Television
Its called a micro-switch and they are fairly generic--look for a parts set similar to yours. If you need the actual plastic button array try Toshiba who might still have it.
Toshiba 50HX81 TV looks kind of old school 3D with red and green hue. Bad bulb? How involved is this to fix and where do I find parts?
No,not the bulb problems.Tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look like.The Toshiba tv have a "HYPER BOARD"known as a convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the convergence board,must be replaced to solved the tv convergence pictures problems.U have tools like a soldering iron,desoldering pump or desoldering braids,solders?Can u do basic soldering?Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop,will cost u $300-350 for parts and labors.
Why is my screen turning red after watching a it
is a red tube problem needs to be replaced, or red output control board is bad. send to repair.
1helpful
Information on seeting convergence for 50hx81 tv
In the customer menu select convergence with the Toshiba remote.
If it is skewed and or will not adjust you have a convergence circuit problem. If this is the case let me know and I will tell you what is involved to repair the set.
I have fixed hundreds of sets with this kind of trouble.
If this has helped you, rate this solution as I do this here for FREE.
SD TECH
Toshiba 50hx81 no picture or sound
If you managed to find a manual or have resolved the problem, please post it back here to benefit others. You probably had a partial or complete power supply failure.
Thanks-
Toshiba TV 50HX81
Check fuses on Power Supply board (F850, F851, F852) and all other fuses. Replace blown fuses (will need an ohm meter to check fuses). I would also replace the two convergence amps (STK392-110's on the signal board, the big black ICs on the two heat sinks). This worked for me.
Toshiba 50hx81 power light just blinks
Go to Powered Products List view all in my profile and read
Toshiba entries........Let me know how it is going.........T.
Toshiba 50hx81 Squiglly Lines
Bad hyper board = Needs rebuilt, technician skill level high....
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
