Since
the tape won't come out then it means you will have to manually remove
the stuck tape. This involves you disassembling the unit in order to
help/assist the player get the stuck tape out.
Turn of the unit
and remove from the wall, get a Philip screw driver, use it to remove
all the screws from the unit and take it apart.
Open the cover and you will see the stuck tape and what's hooking or preventing it from coming out/ejecting.
Now
plug the unit, and turn it on. Press the eject button, as the tape
tries to come out, support it with your hand so that it can come out.
Or
if it happen that the cassette tape has coiled inside the unit,
carefully free the coiled tape and the press the eject button.
Lastly,
the moment you disassemble the player, you would see what's preventing
it from coming out, then you can free whatsoever that is making it stuck
press the eject button and the tape should come out.
Make sure the unit is turned off each time you want to remove what's making the cassette stuck.
Had the same problem. took cover off, cleaned the recording heads. Also look on the left and right of casett chassie.You'll see to thin green strips sticking up with a black elctronic device. Chech to see if it is aimed at the clear plastic pin near the little black plastic gear in the middle. mine was out of alignment on the left one. Works know. Good luck
unplug then remove the top cover press down on the cassette release and remove the tape then rewind the part of the tape still sticking out by hand push in the button on the side of the cassette to open the cassette cover
Generally, you have to take off the cover, and find the motor that
drives the cassette loading mechanism, then turn the motor shaft with
your fingers (many many times) until the cassette is unloaded.
Usually the moter is easy to get at on top just to the right of the
cassette mechanism. However sometimes it is underneath and you
can only get at it by taking everything apart. Don't try this
yourself and don't take the cassette carraige assembly apart trying to
get at the cassette unless you don't plan on using this VCR again.
I am a sanyo VCR technician and i will share to you what i had encountered. the problem of your VCR is in the mechanism "slide front" unable to push out the ejector portion of the tape. If you can locate this part just push it so that the tape will eject.
