Hi My problem is a flashing green power button and it will not turn on. I have held down the power button on the top of the tv and the power button will turn red. Then when I push the remote power button it turns amber then starts to flash green.Thank you for your help
(1) 4tinyhearts said:
I unplugged the TV and held the buttons down and it continued to flash. I continued to hold down the two buttons and replugged it in again and it worked. TV back up and working.
(2) lastditcheffort said:
Unplugged it. After looking for a new tv online I decided to try getting it to work. So, plugged it back in and held down the power button, a red light came on, held down the power button again and an orange light came on, held down power button again and green light came on and tv powered on. This was simply a case of trial and success!
(3) Nateinportland said :
unplug, hold power button, plug in. If that doesn't work, unplug all the HDMI cables, unplug the power, hold power button, plug back in.
Many LED TVs and other electronics have bad capacitors on their power supply boards. You can visually inspect them by opening the TV and looking for capacitors with bulging tops. If you see any, replace them all in the power board section. This should fix the problem. Check to see if your TV is still under warranty first though.
Press MENU on remote. Select "Parental, Favs and Setup". Select "System Setup". Select "Remote". Select "Program Remote".
While aiming remote at device, follow onscreen instructions to program remote to TV, DVD, or other device.
How to program the white DIRECTV remote to your TV
Look up the control codes for your DIRECTV remote control. Make sure your TV is turned on. Slide the mode switch at top of remote to "TV". Press and hold the MUTE button. This is located above the number 1 button. While still holding down MUTE, press and hold the SELECT button until the green light at the top of the remote flashes twice. Enter the first TV code you have. The green light on remote should flash twice. Aim remote at TV and press PWR button once. The TV should power off. Once the TV is able to power off/on and control the volume, slide the mode switch at the top of the remote back to the left (DIRECTV). Your remote is now programmed.
If the TV does not power off, repeat steps 4, 5, 6, and 7, using the next code for your TV brand.
If remote control fails to program using all available codes, try scanning for the code.
How to scan for TV codes on your DIRECTV remote
Make sure your TV is turned on. Slide the mode switch at top of remote to "TV". Press and hold the MUTE button. This is located above the number 1 button. While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice. Then enter 9911, the green light on remote should flash twice. Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off. When the TV powers off, press and release the SELECT button.
Note: If the green light flashes three times before TV responds, then all codes have been cycled through. Our remote controls are guaranteed to program to your DIRECTV receiver, however your TV may not be compatible with our remote control.
You can find more help in the Remote Controls section of our Technical Forums at forums.directv.com. You can also use our Interactive User Guide to learn the ins and outs of your remote control.
If you have a DIRECTV white remote, press "menu" then "settings," "setup," "remote", and follow the on-screen instructions.
If using a gray or black remote,
Here's how to scan for TV codes on your DIRECTV remote
1.Make sure your TV is turned on.
2.Slide the mode switch at top of remote to "TV".
3.Press and hold the MUTE button. This is located above the number 1 button.
4.While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
5.Then enter 991, the green light on remote should flash twice.
5b. Press 1 again (it will flash twice
again), then you press the power on button at the very top right.
6.Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
*If you hit channel up very fast, you risk going past the code. Pressing
channel down will back it up. I alway hit channel up very fast till the
tv turns off, then back it up slowly till it comes back on.
7.When the TV powers off, press and release the SELECT button.
*Note: If the green light flashes three times before TV responds, then
Ok it took me a while. Go to this link to find the codes for you remote: 10054 is the most used code for Magnavox. I hope this helps you out. Good Luck!!!!!!! http://www.directv.com/DTVAPP/content/remote_codes
Here's how to program your DIRECTV remote control:
Select "Remote"
If the TV does not power off, repeat steps 4, 5, 6 and 7, using the next code for your TV brand.
Canon IP 2000 / reset
1. Turn off printer 2. Hold down Resume button and press Power button. 3. Keep holding down Power button and let Resume button go. 4. Press Resume button 2 times then let BOTH buttons go. 5. Green lights will flash and then stop blinking. 6. When green lights are solid, press the Resume button 4 times. 7. Press the Power button and the printer should turn off, if not, press the Power button once more. 8. Your printer should respond as normal..
