Ice maker is leaking and causing significant ice buildup in the bottom of the freezer compartment and also water is periodically accumulating on the floor outside of the unit
Are you sure it's the ice maker that's leaking? We have this model & ours accumulates a HUGE iceberg in the bottom of the freezer, but the water seems to be coming out of the back, at the bottom of the back panel, where the vents are.
The error code 1F on an LG refrigerator indicates a problem with the ice maker fan. The most common cause of this error code is frost or ice buildup around the fan. If you have disconnected the water line to the ice maker, then the most likely cause of the error code is frost or ice buildup.
To fix the error code 1F, you will need to defrost the ice maker fan. This can be done by following these steps:
Unplug the refrigerator or turn off the circuit breaker that powers the refrigerator.
Remove all food and drawers from the freezer compartment.
Open the freezer door and allow the ice to melt.
Once the ice has melted, use a hair dryer or heat gun to melt any remaining frost or ice around the ice maker fan.
Wipe away any moisture with a clean cloth.
Reassemble the freezer compartment and plug in the refrigerator or turn on the circuit breaker.
If the error code 1F persists after defrosting the ice maker fan, then there may be a problem with the ice maker fan motor or the control board. In this case, it is best to contact a qualified technician for assistance.
Here are some tips to prevent the error code 1F from coming back:
Keep the freezer door closed as much as possible to minimize air circulation.
Defrost the refrigerator regularly, even if the ice maker is not in use.
Clean the ice maker coils regularly to prevent frost buildup.
If you live in an area with hard water, consider using a water softener to reduce the amount of minerals in the water that can contribute to frost buildup.
By following these tips, you can help to prevent the error code 1F from coming back and keep your refrigerator ice maker working properly.
start with hose replcement buy parts at sears water hose to main ice maker might have crack in it or the stopper is bad get in ther look close with brite light
First off, if you get in a hurry, you can cause serious damage.
The machine must be unplugged, and allowed to completely defrost.
24 hours would be considered normal, but you can quicken that up some by placing a floor fan in front of the freezer compartment with the freezer door left open.
You can access the drain hose by removing the rear access panel.
Service techs then use compressed air connected to a hose and insert it in the end of the drain hose, and, BLOW AIR THRU IT GENTLY.
2 causes for this problem. one, the drain was in fact plugged up. Two, if the machine has an icemaker, the fill hose from the water valve to the ice maker is leaking, causing water to leak and then freeze in the bottom of the freezer.
If it overfills and drips, look for an
adjustment behind the plastic endcover with a +/- on it. - is less water. If it continuously drips, replace the water
inlet valve on the back where the house water supply comes in.
The waterinlet valve on the back of the unit where the
water supply comes in can have a slow leak and will cause ice to buildup and
block the fill tube. Disconnect the ice maker line from the valve and watch to
see if it has a slow drip. It doesn’t take much to eventually block the fill
tube.
Here I am going to give you a lot of information. Because of the leaking your defrost condensate drain is most likely the reason. All on the page below may not be for your situation and some refrigerators do this over a period of time and the the water has no were to go but the freezer during defrost. Click on link below, Thanks, Sea Breeze HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
If the unit is freezing well in the freezer and your ice bin is defrosting or ice is melting together it is your ice maker over filling the tray causing water to leak into the bin. You can purchase kits that contain all ice maker parts needed , it may be the ice maker and it may be the water inlet valve in the back , both come in the kit , go to sears parts on line with the model number from your unit.
check to see if the defrost drain is not frozrn over or stopped up
this is the only way that water can get into the freezer
frost could and melt but dont think that i would check the drain at the bottom of the rear freezer panel if you see ice it is stopped up for sure
if all is clear there go to the ice maker, have had some that are overfilling and runnig over the ice maker into the bottom of the freezer
