Nokia E71 Smartphone Logo
A
Anonymous Posted on Jun 29, 2010
I want to restore factory settings I dont have pin 2
Anonymous
Level 1:
Problem Solver:
  • Contributor 12 Answers
  • Posted on Jun 30, 2010
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
12
Questions
0
Helped
5834
Points
28
You do not need a PIN 2 code to reset the phone. Go to Settings > General > Factory Reset. The code you will need to enter is the Lock code.Normally, it is 12345 but if you have changed it you will need to remember it.
1 Related Answer
Anonymous
  • 208 Answers
  • Posted on Sep 18, 2008
SOURCE: forgetten PIN code
The default PIN Code for restoring the factory settings is 12345.
Try with this .
incase if it doesnt work
*#7328748263373738# resets security code.
probably this must work .
How to reset samsung led tv to factory settings?
Step 1 Press the "Menu" button on the Samsung LED TV or the remote control. Step 2
Press the up or down arrow buttons and highlight "Support." Press the "Enter" button to open the Support Menu.
Related Reading: How to Reset a Samsung DVD Recorder Step 3
Select "Self Diagnosis" and press the "Enter" button. Select the "Reset" option and press "Enter." Step 4
Enter your TV's security PIN. The default PIN is 0000; however, if you had previously changed it, enter the new PIN. Step 5
Select "Yes" to confirm your selection when the "All settings will return to factory defaults except network settings" dialog message appears on the screen. The TV powers off automatically and restores the default factory settings.
How to Reset Samsung LED TV to Factory Defaults
FACTORY RESTORE WITH
The simplest and quickest way is to take the Cmos battery out.
Wait 10-15 min. Then re-insert this should put the system back to defaults. You may also have to Rest the Cmos.
Find the Cmos reset jumper on the Motherboard. Jumper should be on pins 1 and 2 (default). Put jumer on pins 2 and 3. Do this with the Power off and plug pulled for outlet. wait 10-15 sec and place the jumper back on pins 1 and 2. Plug machine in and restart.
Image here for reference. (I'm using this image alot today!) :)
When prompted to set a password,
You can input a new password or leave it blank.
Good luck hope this helps.
Need to restore the factory settings of my D15 cherry mobile phone and i dont know the pin code or password.
Those Code is not working in my phone., anyway how to use it?? just type those no. and dial it.. is that it??? Please my Cp is C5i
I badly need to restore it.. i forgot its passcode..Please
Thanks
May 19, 2011 • Cell Phones
2helpful
2answers
How to restore to factory settings latitude D600
hi,
the d600 has a 8 pins chip,like the c600 where the pasword/faxtory
setting is stored..
it's located under the tape where the pcicma socket is..close to edge of the board
it sais:UPW1
I think you can use the paperclip methode like the c600
wich means short two pins ( 3& 6) while you power the lap
Cant remember the pin for my tv can you please help
Unplug the tv from all power source for a good 12-24 hours. However before that, have your tried a restore back to default settings? In general you would hold the menu and power button at the same time for a few seconds to "reset" the tv, and thus no more pin, then you can make a new pin once default is back. Also if your pin was a pin set from the factory you can contact them to get the default pin for your tv, or do search online if the pin was generic. Other steps can be done if those dont work but yes, your issue can be fixed.
21helpful
4answers
Restore factory settings
HOW TO RESTORE FACTORY N72
How do i restore factory settings to my packard bell desktop
If you want to restore your computer to factory settings, and you dont mind losing your files, you will need to get the cd recovery disc, put it in the cd-rom drive and reboot your computer. it will start the process from there.
beware, it will erase everything that currently is on there and when finished bring the computer to the original factory settings.
1helpful
Forgetten PIN code
Try with this .
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
