Konica Minolta DiMAGE A1 Digital Camera Logo
Posted on Jun 29, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
A1 Dimage rubber eye piece for viewfinder? - Konica Minolta DiMAGE A1 Digital Camera
Anonymous
Level 3:
Brigadier General:
  • Master 3,006 Answers
  • Posted on Jun 29, 2010
Anonymous
Master
Level 3:
Brigadier General:
Answers
3006
Questions
0
Helped
959181
Points
10121
I've had the same problem. You simply can't get them new, but you can salvage them from the many scrap A1's and A2's which have suffered circuit board failures. Take care as you peel it off the old camera though as it's very easy to tear. Best reglued with a few very carefully applied smears of superglue. If you want your camera to last, then afterwards use a bit of double-sided foam based sticky pad to secure the viewfinder in the down position: leave it free to move and it WILL fail (I'm amazed it hasn't done so already). Basically there's a poor design which causes the flexible circuit board to crack and once it goes it usually cannot be repaired.
A whole scrap camera is usually quite cheap on auction websites, but ask questions to ensure that the item is supplied to you before the previous owner has harvested all the all the useful bits, such as batteries and caps.
There is an ebay seller in the USA who sells an alternative eyecup which will just about fit, but it interferes with the viewfinder's ability to lay flat and also looks very amateurishly applied afterwards. The original item is by far the best.
Hope this helps, please take a moment to rate my answer.
  • Anonymous Dec 07, 2010
    I used JP service Solutions in Staffs UK. Service no 01782 753344
    Very helpful, parts and repairs for minolta cameras.
2answers
Viewfinder shows only streaks
if the pictures are like that as well, chances are your CCD sensor is on the way out. if only on the viewfinder (so pictures are OK) it may well be the display of the viewfinder that is also known to give problems although much less... however, if the viewfinder is the problem you should be OK to use the cam. in case you did not replace the CCD, i would be careful spending any money. i am now trying to get the 3rd CCD in my cam... they are really a problem.... I have 2 of these and they seem to keep on failing on the CCD's. pity, since i really love this camera...
ton
Konica minolta dimage a1
Sounds like a CCD fault. Many A1 users, including myself, have had this. Allegedly, Sony, who made and fitted the CCD sensors, had a manufacturing "issue" at the time. Many A1s were recalled and others, including mine, have been successfully repaired free of charge by Sony on request. I suggest that you contact your vendor or a local repair shop to discover whether this service is (still?) available in your location. It's well worth the effort as this is a fine camera. Good luck.
2answers
Minolta dimage 7i powers up all functions but lcd and viewfinder are blank
You both are in luck. This sounds like a defective Sony CCD issue. Sony will fix your Minolta camera for free (with free shipping) regardless of warranty. You need to do this before March 31, 2008 so get going! See this link:
http://esupport.sony.com/US/perl/news-item.pl?template_id=1&news_id=131#
The Dimage models that Sony is accepting for the recall repair are:
Dimage 7HI, 7I, A1, Xi, F300, XT, X20, S414.
Black screen cannot take picture minolta dimage a1
i have seen a recall notice on this camera - you can send it sony konica minolta for free repair.
search web for details.
Viewfinder
Please check the rotary switch on the camera is in the correct position. The viewfinder and monitor settings are very close together! You can download the manual from the link below: http://ca.konicaminolta.com/support/manuals/digital_cameras/dimage-z/dimage_z10/D_Z10_E.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
What are the main features of DiMAGE A2?
It has succeeded from A1's concepts, "Providing the more enhanced image quality," "Reducing the mis-recording," "Not limiting its users or scenes" and "Providing the unexpected satisfaction, pleasure and impression" from the DiMAGE A1. Compared with A1, it is the all-in-one type digital camera achieving not only the still image but the high quality of viewfinder and movie. - 2/3 type interlace scanning CCD with primary color filter and 8 million pixels - VGA-size with a high precision EVF (922,000 pixels) is loaded to check the focus more easily. Compared with A1's EVF, about four times the high precision display is enabled (A1: 235,000 pixels). - Depth-of-field preview - Movie recording function of 544x408 size with 30fps - USB 2.0 support (high speed mode) which can transmit large data in high speed - PictBridge support Furthermore, 3D AF to track the movement and keep focus on the subject and anti-shake compensation functions inherited from A1 are also loaded.
What optional accessories are available for the DiMAGE A1?
The followings are available as optional accessories for DiMAGE A1: 1. Battery pack BP-400 2. Digital Utility Bag DUB-100 3. DiMAGE Capture which software can be controlled DiMAGE A1 from PC ( It will be available September ,2003)
Is the viewfinder of the DiMAGE 7i high eye-relief type?
Yes, the eye-relief is approximately 20mm from the eyepiece lens and 17.5mm form the eyepiece frame.
Bundled Eye Piece Cover
The Eye Piece Cover is the cover that attaches to the viewfinder. The eye piece cover prevents light from entering the viewfinder when shooting with your eye away from the viewfinder.
Top Konica Minolta Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Bill Eager
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
