How to adjust carburetor on echo model gt2000 type 1-E grass trimmer ? engine will start but will not keep running. just finished overhauling carburetor, used rebuilding kit #RB64 (ZAMA)
Most modern carbies have fixed jets.some you can pry off the caps and adjust,but usually if you need to adjust carbie,youve got other problems.stale fuel,not enough compression,vaccuum leak,spark plug faulty[oiled up]carb gaskets letting in air,needle valve adjustment causing diapragm to not open it enough.used the wrong gaskets in the kit[sometimes they have different model gaskets in one kit
