Every BlackBerry has "Subsidy code" or "Sim lock code". To remove BlackBerry subsidy code or sim lock a special Blackberry IMEI Unlock Code is needed. By entering Blackberry Unlock Code on your BlackBerry you can use your Blackberry with any GSM and SIM card around the world. Blackberry Unlocking is simplest way to remove any or carrier restrictions from your Blackberry. Remote IMEI unlocking is the safest and fastest way to unlock a cell phone.
Get this Blackberry curve 8100 Imei Unlock Code .i hope this will help you :)
Good Luck.
Imei number is just a steping stone to get blackberry 8100 unlock code. The next thing that you need to do is purchase a blackberry unlock code from third party sites, in this case your imei number is needed to generate that unlock code.
There are two methods for unlocking Blackberry 8100 by MEP number and by IMEI#.
The simplest method for unlocking by IMEI#.
You can find your Blackberry 8100
IMEI number by follow one of these steps.
1.By Pressing *#06# into the phone.
2.On your Blackberry cell phone, go to Options-->Status.
3.put the battery out,there should be a white sticker it will show your Blackberry IMEI #.
This Blackberry Unlocking codes provider provides unlock code for Blackberry 8100
Hope this helps.
