This is an error for the fuser the thermistors have not registered the temps properly check the fuser and if you know how to take it apart clean the thermistors.. you could try an sc reset using the following proceedure...Yellow clear button then 107 then hold down the stop button..wait for the screen to change to show copier sp turn off the machine and wait 5 secs then turn off. If this doesnt reset do the same proceedure on the copier sp enter this then look for mode 5. enter this mode and look for 810 sc reset and set this then turn off wait and turn back on....if this error occurs regularly the thermistors will have to be changed.. hope this helps..A
