Does not go into spin so it does not drain, how do I tell if its the pump or the electronics? It just makings a hum/buzz noise when it should be spinning/draining, then it continues into agitation. Could the drain pump be jammed? Where do I check to see if it's pluggage/jamage.
Thank you
I appreciate your post, Rachel Kovach!
From my understanding your Frigidaire frontload washer is not spinning the final spinning and the clothes are still wet. If you washer is overloaded it will not spin properly to release the water out of the clothes. Also, a small load will cause your washer to not spin properly. You should additionally check the drain hose to make sure it not kinked or twisted that could cause your improper draining. If all that checks properly it could be an issue with your drain pump, motor, and control panel. I would suggest consulting with a technician for proper diagnosis and repair. This will help avoid unnecessary part purchases. -Matt
