Lands Phones Logo
Posted on Jun 28, 2010
Bluetooth doesn't fit into charger box properly so I am unable to charge my bluetooth.
Anonymous
Level 1:
  • Contributor 30 Answers
  • Posted on Jul 25, 2010
Anonymous
Contributor
Level 1:
Answers
30
Questions
Helped
7552
Points
57
Perhaps you got the headset with the wrong charger dock, you should take it back to the store and test another one there if its the same problem alert the store to this manufacture default...recalls may be in order
2answers
I have a H680 ear piece newly removed from box.iam unable to charge it although the red light comes on when placed on charger it fades away within seconds have left unit on charger for at least 3 hours but...
James
Sorry you are having an issue. Have you tried another charger? If so and it still doesn't work. CONTACT US . If you have proof of purchase that it was purchased new less than year ago then we'll replace it.
Mark
Motorola Support
My galaxy 3 phone will not charge properly how do i fix it
Charging issues is a process of elimination. First the charger....many chargers will fit but not all that fit will work. A bluetooth charger will fit but would never charge your battery completely. Make sure you are using a proper charger. 2nd is the charging port on the phone. If the charger is loose it could be a bad port or the prongs on the charger are not holding....is it loose? Or if there is corrosion on the port. If corrosion, clean with alcohol and tooth brush. 3rd is the battery. If its swollen, then it's toast. A li-on battery will start to decrease after 400 to 500 charges.
Jawbone up wont charge
It may be the problem of the charger or the battery, please check them. If the battery is unable to charge or keep charge then replace it.
If the charger is unable to supply sufficient charge or no charge then replace it with a new one.
1helpful
How do i charge this device?
Is there a Model number on this bluetooth, can't find RoHs....
At Walmart and Stores like that they have different chargers that have different charger ends pieces, you can try to see if any of the ends fit in the charger slot at the end of the bluetooth. Most of these universal chargers have end pieces hanging out of the package, so take your bluetooth and try different ends. Example but do not know if its the right one is:
http://www.walmart.com/ip/Northwest-Charger-Pro-All-in-One-Charging-Kit/22426335
May 09, 2013 • Cell Phones
1helpful
2answers
Unable to turn on my plantronics 210 explorer bluetooth .therefore no light is showing in it. charger is fully charged
My LG hands-free HFB-500 Bluetooth doesn't get charged in my car. I live in Florida and it is sunny almost every day. I don't remember a charger adapter being included in the shipping package. ...
Depending upon the make and model of your car, you may have a windscreen fitted which blocks most of the wavelengths which solar chargers particularly rely upon.
To test that idea, leave the charger out in direct sunshine sometime when you can safely watch over your equipment and see whether it charges or not.
Jul 15, 2011 • LG GPS
2answers
My headset will not turn on
Hello
Your bluetooth headset is powered by an internal battery. If the battery is not charged,it just won't turn on. Fully charge your battery before use.
Make sure that the power outlet you're using is working and that the cord is fitted correctly into the wall, PC or Car outlet and the Jabra Bluetooth device.
Try unplugging the Jabra Bluetooth device and see if it turns on. If so, use the Jabra Bluetooth device until the battery is completely exhausted. The next time you charge it, check that it is charging properly
If the Jabra Bluetooth device is still not charging, check what happens when you initially plug the Bluetooth device into its charger. If the light on the Bluetooth device flashes on and then off again quickly, it is likely that the battery is no longer working. Batteries cannot be replaced or covered warranty
3answers
Lost charger who can I call?
The nice thing about the ps3 is it can charge the bluetooth from the charge cord for the controllers. Just plug the bluetooth into the charging wire from the ps3 and the bluetooth will charge.
Top Cellular Innovations Lands Phones Experts
k24674
Are you a Cellular Innovations Lands Phone Expert? Answer questions, earn points and help others
