My TV is strictly a game TV. It has no antennae for cable or satellite. It's just for Game Cube, Wii, and DVD. My little brother tried to watch a DVD and he accidentally hit the menu button on the TV and now our TV only shows that black and white static stuff, you can't even watch movies. It acts like it's not hooked up to anything even though it is. I tried unplugging it but that didn't work.
SOURCE: Power Outage - now DVD will not play through AV
I am having the same issue with mine. I even set everythign back to factory defaults and it still wil not work. Isn't there any tech support palced to find help? See post by Scriptster. Thanks
I believe that what you are watching are the responses of the portable DVD player on screen menu. How about just trying to get the tv to work for now, then try the DVD again?...accordianman
SOURCE: Emerson EWT2721 a/v cable connections won't work
you might have to press "game" on your remote, or press an input button
SOURCE: The remote to our TV is caput - has been for years
Unless the TV has an input select function available from the front panel buttons, you're out of luck. Many sets only have basic functions through the front panel and rely on the remote for the rest. The original remote had a button to switch the inputs and now you need it back.
The only sure solution is to buy an exact replacement remote. There are several companies online that can probably provide one. They tend to be costly, though. Your other option is to look for a universal replacement that has a button marked "input" or "tv/av" or similar, and hope it will work with your set.
One more option is to get an RF converter, available at TV retailers, Radio Shack, etc. This device takes the audio and video signals from another device and converts it to a channel 3 or 4 output signal that your TV can tune in. Then you can just put the TV on that channel. It would work, but you lose some picture quality and possibly stereo sound effects.
Sorry I don't have a happier answer. Thanks for using Fixya.
SOURCE: Admiral TV model GRD15272 video/dvd
Using the buttons on the TV, go to the setup menu, and scroll to "edit channels" by pressing "setup" button until "edit channels" is highlighted. Then, using the channel up/down buttons, go to channel 91 and press + volume. This should add the video input to your channels. 92 is S-video. It is helpful to have what ever device (dvd player or game console) hooked up and powered on, so you know when you are on the right channel, but it should be 91.
