American Standard Kitchen Faucet 6310 020 White Easy Touch Pull-Out Kitchen... Logo
A
Anonymous Posted on Jun 27, 2010
We have a problem with the cold water flow as it just trickle out. The hot water flow is fine. We have the Combi Faucet 6310 series
Anonymous
Level 2:
New Friend:
  • Expert 61 Answers
  • Posted on Jun 28, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
61
Questions
0
Helped
39667
Points
111
I would check take apart the cold flex connector and check the flow when running water into a bucket, if it is wimpy then there is a blockage in the angle stop or the flex connector. If it is good you will need to take the cartridge out, check for signs of debris and possibly replace it
I have a Vaillant Combi boiler, recently serviced by British Gas, given all clear. Problem we are having is the downstairs hot water tap it is a mixer tap, the cold water is fine but the hot water is
Boilers are inherently dangerous for the average DIY for so many reasons, contact British Gas and have them come back and fix it, tell them it was fine before the "service". They may simply have a control valve shut off.
I replaced a moen 1222 valve stem becasue i had just a trickle of water. I go the new stem in ok, but still no water. I have the hot water heater diconnected on the water inlet, but the out let is still...
With posi-temp cartridges, if one supply of water, hot or cold, is interrupted, the cartridge automatically restricts the flow of the other water source. This is to prevent you from getting scalded if the pressure on the cold side drops because of a toilet being flushed or any other uses of cold water. The cartridge will only allow cold water to flow through if there is hot water to balance it out. If you restore hot water to the faucet, it will operate properly.
I just had a new price pjister series 40 (Ashfield collection) single control lavatory faucet installed. Our contractor installed it yesterday and he is now out of town for a week. Since the sink and...
You have already checked the two obvious things now make sure the two supply lines from the shut off valves are not kinked or turned it such away as to close off the water flow. If that is ok then there may be some debris in the internal filter screens.
Keep in mind that this faucet design will not put water out at a high pressure if it did it would splash all over the place.
IF HAVE A AMERICAN STANDARD KITCHEN (6310) . I JUST READ THE PART TAKE FACTCET APART AND TURN ON WATER . I DID THIS AND GET WATER ON COLD SIADE BUT NOT ON HOT. THIS IS WITH CARTRIDGE OUT .DOES THIS TELL...
It says you have a problem with the hot water. First thing to do is to turn the hot water supply valve under the sink off, and then remove the line from the valve to the faucet at the valve. Then put a bucket underneath the valve and turn it on (carefully). If you don't get any flow, then the problem is in the valve or the pipes supplying the faucet. If you get flow there, then the problem is in the supply line or possibly at the faucet.
3helpful
I HAVE A SINGLE HANDLE HIGH NECK BLANKO KITCHEN FAUCET THAT IS RESTRICTING THE FLOW OF WATER WHEN TURNED IN THE HOT POSITION. THE WATER IS FLOWING FINE IN THE COLD POSITION BUT WHEN TURNED TO HOT...
If water come out the faucet hot line,check if is clogged.For this job you need to disassemble the faucet.
Here is a good PDF source to do it.
If you need more help come back.Post / thumbs / testimonial are welcome!
Cold water works, hot does not
your problem can be fixed by running a loop in the plumbing. If you hired a professional in the first place it would already be done. basically the water pressure isn't enough, i bet your faucet is on the second or third floor, or even just THAT far from the water heater.
2answers
The hot water stops coming out of faucet
if this is the faucet in picture, turn off water, pull out cartridge and inspect for any debris in cartridge or valve body, if not, turn on hot water to see if water is getting through valve body. May have kinked line or debris from or in angle stop line.
Only cold water in my tub hot only trickles
Usualy when this happens you need to change out the cartrage that controls the water. try to find your faucet at the link below. If you find it click on it scrol down and you can view the manual. It will terr you how to change it out.
http://www.deltafaucet.com/bath/index.html#tubshower_
Good Luck
Top American Standard Plumbing Experts
john h
Paul Carew
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
