1. Fix Internal Cooling. The first and most important thing you need to do when your
laptop is
overheatingis to clean the fan(s) that provide(s) cooling to the CPU and graphics card.
Over time, they build up layers of dust and dirt that slow them down and block airflow.
A
laptop that severely
overheats causes damage to the internal components. Before this
happens, the
laptop should attempt to shut itself down. ... If you smell smoke, a burning odor, the fans never run or the fan runs all the time, be careful to avoid ruining your
laptop.
The most common
cause of
laptop overheating is a non-working fan. ... Viruses, spyware, adware and other types of malware put a heavy strain on the CPU and other components of your
laptop. This
causes those components to heat up, often to a point where the fan simply cannot move enough air over them to cool them down.
Determine Whether Your Computer Is Overheating or Just
Hot.
Laptops get hot. It's what they
do. However, if your
laptop is shutting down, suffering from the blue screen of *****, or experiencing serious slowdowns, then you have a much bigger problem on your hands.
A
happens, the
laptop.
Heat is a computer's enemy. Computers are designed with heat dispersion and ventilation in mind so they don't overheat. If too much heat builds up, your computermay become unstable, suddenly shut down, or even suffer component damage.
IF you need more info on laptops or computers go to this link... laptop over heating Google Search
