1998-2002 Nissan Frontier with 2.4 L KA24D and KA24DE class engines , Cylinder Head Bolts Tightening Procedure :- you have total of 10 bolts , 5 on the LH of engine and 5 on RH ( LH is the intake side and the RH is the exhaust side ) : starting from center LH #1 , #2 on RH center side , #3 LH front of #1 , #4 RH behind #2, #5 RH before #2 , #6 LH behind #1 , #7RH engine front corner , #8 LH end of engine corner, #9 LH front engine corner and final #10 bold is RH end of engine corner .
the Torque spec steps are as follows :
step A- tighten all bolts to 29N-M ( 3.0 kg-M or 22 Ft lb ) step B- tighten all bolts to 79 N-M ( 8.1 kg-M or 59 Ft ib )
step C- loosen all bolts completely .
step D- tighten all bolts again to 25 up to 34 N-M ( 2.5 up to 3.5 kg - M or 18 to 25 Ft lb )
step E- using angle wrench ( turn all bolts clockwise 86+ - degrees ) if you don't have an angle wrench ? do as follows : as final step : tighten all Bolts 75 up to 84 N-M ( 7.6 up to 8.6 Kg - M or 55 to 62 Ft lb ) .
end of procedure .
mute button top LH corner under screen
to turn it down
press menu
scroll to answering set up scroll to volume press menu adjust to low press menu and then end
Hi Elizabeth
I would have to assume that the printer is plugged into a computer via USB or an Ethernet cable?
On an Apple Mac computer you would go to the top LH corner Apple & choose System Preferences. In preferences look for the Sharing Icon. There is a tick box in here for sharing your printer. Turn off Printer Sharing.
