We have a Sony Bravia KDL46V3000, manufactured 7/2007. When first turned on, the screen is very dark, especially on the left side. There are also 3 or 4 horizontal bands visible, especially on the left side. After about 5-8 minutes the screen brightens up and goes back to normal. It only happens when the screen is cold, not after it has warmed up. Please help!
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
On the WEGA the panel control module and possibly the left side planer board is done for. On the other sounds like the planer board on the dark side is done a well. Get your son a Gaming type monitor cause this will continue to happen due to the higher refresh rates demanded on the gaming software. Sorry Ed Pinero
I have the same tv with the same problem. My tv is about 3 1/2 years old. I took it to the shop yesterday and today they told me that I had a bad lcd panel and a bad FL1 circuit board. They also told me it was going to be $3800.00 dollars to fix. I am now on my way to buy another tv, needless to say it will not be a Sony. Sony knows about this problem and refuse to do anything about it. Good luck.
6 blinks indicates broblem with florecent backlighting. Check and tighten screws on the inverter boards. There are two boards on the upper left and right. Check that the connectors are in good. Check the pins in the connectors that the wires are attached good. This is a start. If this is under a year old or close to that have seviced under mfc warr. Call sony if expired they may help.
