Once your on the erase screen. Navigate to the erase button by pressing on the side arrow of the circular control on the back of the camera. Once the "erase" is highlighted, you can select by pressing the center or set button. You may need to confirm by pressing again.
You can also erase all by accessing the menu and then navigate to the ERASE ALL on the menu and hitting the set button.
You go to the menu in Review mode and on the Play tab you will see a function for Erase and under there is a function called All Erase. This will erase all of the images at one time. There is also an option to go to Setup and go to Format option. This will also erase all images at once but they will be gone permanently from the memory card.
Image protection and erasing are covered on pages 64 and 65 of the manual (you can view/download the manual here). If you are going to erase all images, you can just initialize the card (see page 65). It will erase all images, even protected ones.
Press the trashcan/folder icon to erase a single image. Press and trashcan/mulitple folders icon to erase many images, all images, or to format the SD Card. It is good to Format the SD Cad from time to time after downloading the images to clear all residual memory files (even if you do not see them).
Press the trashcan button to erase a single image. Press and HOLD the trashcan button for the option to erase many images, all images, or to format the SD Card. It is good to Format the SD Cad from time to time after downloading the images to clear all residual memory files (even if you do not see them).
Please follow these steps if you would like to erase all your images at once. Use the arrow keys on the keypad to navigate through the menu.
Steps:
Turn Mode Dial to Play Back Mode (green arrow).
Press "OK/Menu" button
Select "Mode Menu">"Card" tab
Select "All Erase">"Yes"
