MS-MVP - Elephant Boy Computers - Don't Panic!
The First Question Of Troubleshooting: If the problem is new, what changed between the time things worked and the time they didn't?
The Second Question of Windows Troubleshooting: what is the malware/virus status of the machine? If you think it is clean, what programs (and versions) did you use to determine this?
Be sure the computer is clean:
http://www.elephantboycomputers.com/page2.html#Removing_Malware
If the computer is completely virus/malware-free, manage your startup to find the culprit.
Start>Run>msconfig [enter]
This brings up the System Configuration Utility. Look on the Startup tab and find the probable culprit. Uncheck the box next to its name, Apply and OK out. You don't need to restart immediately, but the next time you do you'll get a dialog saying you've used the Utility. Just tick the box that says in effect, "don't bother me about this again".
How to Troubleshoot By Using the Msconfig Utility in Windows XP - http://support.microsoft.com/?id=310560
The free Autoruns program is very useful for managing your Startup - http://www.microsoft.com/technet/sysinternals/default.mspx
SOURCE: i have problem when i start my pc a error message
This problem usually occur due to soft booting the machine (reset) and then it could not restart. Usually after the xp logo screen u can only got the parser message: string table not found '42' at line 462. (which is a registery sincronization error (r,sint)). Click the ok button many times and your machine will boot up. Then go to control panel, user accounts, create new account. soft boot your machine again log onto new account and delete all files found in file search with stylexp and tgtsoft in them. Tthen log off and restart and log on as usual user (p.s. administrater privalidges required on both) and delete the new logon account. Hope this will fix the problem, otherwise you have to format your hard disc and reinstall your OS.
SOURCE: RCINT failure string table Id not found '42' at line 42
dod't afraid contact me [email protected]
Hope this helps. Please rate my response.
Thanks.
Have a good day.
