EMachines Support > ET1331 desktop computer > Product Views > Rear View,
http://support.gateway.com/emachines/desktop/2009/emachines/et/ET1831/ET1831rv.shtml
The metal covers that have the Plus sign ( + ) holes, are Expansion Slot Covers.
Insert a flat tipped screwdriver blade in the + sign hole.
Insert the screwdriver blade horizontally, in the + sign hole, on the right side. ( ---- , not vertical I )
Gently bring the back of the screwdriver down.
This will make the metal slot cover, bend the small metal tab that is holding it.
Go to the + sign hole on the Left side. Do the same on the Left side as the above.
Bring the back of the screwdriver up.
Keep working the metal expansion slot cover back, and forth, until the two small metal tabs that are holding it in, break.
Remove the metal expansion slot cover.
Before you begin, ensure that the expansion slot cover you wish to remove, lines up with the wireless adapter card.
Have any questions concerning this, post in a Comment.
If you were to log on to the
manufacturer's web site, I think you will be pleasantly surprised as
usually one is able to download, by model number, Driver
downloads
as required.
Just Google the manufacturer's name and
follow the links. Make certain you are directed to the manufacturer's
web site as some search engines direct you to other sites and they
charge for the information that is normally free of charge.
I hope this helps.
