SOURCE: Router Configuration in "Wireless Client" Mode
Hi, If I understand you right, what you want to do is to make the DI-524 as a repeater, i.e. receive from the "external wireless access point" and re-broadcast to your "small home wireless LAN". Unfortunately, no. D-Link made it a point not to enable repeater mode in the DI-524 model (firmware has no support for wireless distribution service). Other than your old DWL-900AP+, one other model they have that can do this is the DWL-G710 but only in WiFi and not in the Ethernet port. On some other brands of similar feature models, the original manufacturer's firmware may be replaced with an open source firmware with more features enabled. An example is the LinkSys' WRT54G and the replacement firmwares by Sveasoft and another named DD-WRT. Hope this be of some information to you. Post back should you require additional information. Good luck and kind regards.
SOURCE: Internet Won't Work on PSP
i finally got my D-link WBR-2310 i found out ..
what you need is to do is Uncheck the box on the 802.11g Only Mode uncheck then you will be able to use psp online.
Good luck.
SOURCE: D-link WBR-1310
The software that was installed for the router should have detailed step by step instructions to get the pc online. If you have followed all the steps try below.
Check and see that the modem is enabled for the computer. There is also a place to troubleshoot the modem connection there.
Note
In that list you will see modems, click the box for the drop down and right click the correct choice (if more that one) then click properties and make sure the device is enabled.
SOURCE: D Link DIR 635 - need to reset user name and password !
You can press the reset button on the DIR-635 which will reset the device back to it's factory defaults. Then connect using the factory default user id and password. (ID: Admin password is blank)
SOURCE: D-LINK ROUTER PASSWORD
hello... I have one problem,,I forget to password my router air plus G+. so, I want to reset my router,,how?
