HP Officejet 4355 All-In-One InkJet Printer Logo
Posted on Apr 15, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hp 4355 cartridge error
I cannot print the panel shows cartridge error. Refer to device documentation to troubleshoot
what is to be done?
  • catridge error
  • refer to device documentation to troubleshoot
  • 5 more comments
  • Anonymous Apr 18, 2008
    yes this is aproblem
  • Anonymous May 06, 2008
    i have problem fased like i seen in screen project manager bryan clement
  • Renachavez Jun 03, 2008
    El mismo Problema
  • sengu_1974 Jul 21, 2008
  • Anonymous Aug 20, 2008
    how to solve this problem
  • lylesti Sep 11, 2008
  • shahmp3 Jan 13, 2009
    same here...please help
Anonymous
Level 2:
Sergeant:
  • Expert 253 Answers
  • Posted on Jun 30, 2008
Anonymous
Expert
Level 2:
Sergeant:
Answers
253
Questions
0
Helped
184727
Points
802
Cartridge use same number.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 01, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1470
Points
Please send me solution on my mail [email protected]
Hp4355 print catridge error
Each cartridge having printing life, as long as cartridge health condition is good it won't gives any trouble. Subjected series printer having mono & colour cartridges,1. Remove both cartridge from the printer 2. Switch on & wait till message appears for insert the cartridges..3. Insert mono(Black) cartridge, close the door & wait till message appears on screen. If message appears same as cartridge error mean that mono cartridge is faulty replace it, if message appears like insert another cartridge, it's confirmed that colour cartridge faulty.. Replace it..
1helpful
2answers
The printer is showing a message catridge error - Refer to device documentation to troubleshoot.
This is an internal electrical malfunction within the cartridge - I suggest you run the following two service tests:
1) You can 'temporarily' bypass an 'Incompatible Cartridge' error (or any other cartridge electrical malfunction error for that matter) by accessing the OJ's service menu...see the Inkjet411.com support youtube video found here:
HP Officejet J4500 J4600 4500 Cartridge Error Bypass -- HP 901 Cartridge Errors: http://www.youtube.com/watch?v=I4-m_RLdRE4
2) You can also run the 'tap 41' diagnostics check on the HP 901 cartridge(s) electrical health, via the access code/procedure shown in the following video:
HP Officejet J4500 J4600 4500 Printers Tap 41 Diagnostics -HP 901 Incompatible Print Cartridges: http://www.youtube.com/watch?v=S6uATgXxQlE
My printer Model no. 4355 officejet gives an error name Cartridge Error refer to device documentation to troublrshoot. Plz tell me what can i do?
Cartridge error means the total failure of a print cartridge. Purchase a new one and replace, it will start working.
Printer Cannot fax n call
When this error appears in your printer check if ink are smeared on the holder where the contact panel is with the cartridge. To fix this issue use the Kleenex(perfume ) added with few drops of water to dampen it and clean off those contact on the holder. You should let the unit sit 24 hours for best results. Before printing anything run aligned thecartridgesa couple times then run clean cartridges a couple of times. Print the test page to look for the condition.
Thank you !!
2helpful
2answers
Cartridge error
Please first check whether there is paper jam in the printer roller or else please check the cartridges is fixed properly
26helpful
5answers
HP Officejet 4355 All in One Cartridge Error
your cartridge may be faulty if you change cartridge and message display same problem so clean catridge block contact with soft cloth clean cartridge back side using student eraser if problem will continue so contact your hardware technician
7helpful
k24674
Grand Canyon Tech
Grand Canyon Tech
