Question about Pride Go Chair Travel Power Chair
My Pride Go Chair battery appears to discharge quickly after a full charge. The controller power light moves from green to red. Then after turning the chair off then on I get more green lights. The battery is 3 yrs old. Could it need to be replaced?
    New Friend:
  • 31 Answers
Yes prob one of the batteries are bad, but you may want to replace both.
Posted on Jun 26, 2010
6ya staff
SOURCE:
What dose red or yellow blinking lights on my jazzy pride electric power chair mean /
  1. VR2/VSI DIAGNOSTIC FLASH CODES
# OF LEDS
CODE
CAUSE
POSSIBLE SOLUTION
One red LED
Low battery voltage
Charge batteries
Two red LEDs
Left motor open
Make sure left motor is plugged into controller.
Three red LEDs
Left motor wiring fault
Contact your authorized Pride Provider.
Three red LEDs One yellow LED
Right motor open
Make sure right motor is plugged into controller.
Three red LEDs Two yellow LEDs
5
Right motor wiring fault
Three red LEDs Three yellow LEDs
6
Inhibit active
Three red LEDs Four yellow LEDs
7
Joystick error
Three red LEDs Four yellow LEDs One green LED
8
Controller error
Three red LEDs Four yellow LEDs Two green LEDs
9
Brake fault
Make sure both motors are plugged into controller.
Three red LEDs Four yellow LEDs Three green LEDs
10
High battery voltage
What if the speed LEDs on the VR2/VSI begin to flash?
  • Determine if the battery charger is connected to the power base. When the battery charger is connected to the power base, a charger inhibit feature keeps the power chair from driving. This is indicated by the VR2/VSI speed
    LED(s) flashing.
  • Determine if the charger harness fuse has blown. A blown charger fuse can cause the charger inhibit to
    activate.
  • Determine if all controller connections are plugged into the power base properly. If the 3-pin charger
    inhibit connector is not plugged in properly, then the charger inhibit feature will activate.
Oct 05, 2017 | Pride Health & Beauty
My battery charger for my Jazzy 600 does not light up or get warm when I plug it in. The chair has not been used for months.
I tried to charge my jazzy. The charge light (red) remained on for several hours. Finally I moved the wire slightly the charge light turned green than faded to red. What is my problem? Your solution would be greatly appreciated.
Jun 04, 2012 | Pride Jazzy Select 6 Indoor Power...
The power chair does not show a charging green light,although the red light is on.... Batteries???
The green light won't come on until the batteries are fully charged now if after an overnight charge you still don't have a green light then I would replace the batteries. Hope this helps you
Feb 24, 2011 | Pride Jazzy 1103 Ultra Standard Power...
Why do the batteries on my Pride Go chair dies out so quickly after a full charge (ie.,both of the lights on my charger have turned green) I weigh about 210 lbs and I put a back pack that weighs about...
I would check the weight limit on the chair first ,You should be able to see that in your handbook given with the chair.
Second I would see about load testing those battery's ,Go into a auto parts store ,or battery store if in fact you don't own a load tester. make sure both battery's can take a load if not that may be your problem.
Good luck happy to help.
Jan 13, 2011 | Pride Go Chair Travel Power Chair
Battery discharge quickly, I have replaced new batteries and module control and problem still exist.
Don your charger is probably not charging the batteries. When you charge your chair overnite the charger should have a red and green light showing charge complete. When you first plug it in the lights should be red and yellow. If you are getting a red and green light when you first plug it in then there is a problem with the charger or with the charging circuit to the batteries. You should have a charger port on the battery box try plugging the charger into that port and see if you can get the batteries charged. When you do you should have a red and yellow light on the charger changing to red and green when fully charged. Hope this helps
Nov 07, 2010 | Pride Go Chair Travel Power Chair
I fitted new batterys, now the joystick is reading low battery but no responce from the joystick.the batterys are wired red to red and black to black does the chair turn this to 24v itself, theres no...
Will you don't say what chair you have and they can all be wired differently. Look under the shroud that covers your batteries and see if there isn't a wiring diagram there. If you let me know the brand ie: Pride Jazzy, Invacare M51 etc. I can give you the proper wiring for the batteries. Now you also didn't say if you charged the batteries after you installed them. Remember always charge before use. Just because they are new doesn't mean they are charged (in fact they could have sat on the shelf for a while). Make sure that they are no older than 4 months old even new batteries can be bad. Charge these puppies overnite. When you plug in the charger you should see a red and yellow light after charging overnite you should see a red and green light( indicating full charge) If when you plug the charger in you get a red and green light then something isn't wired correctly. Hope this helps
Oct 27, 2010 | Health & Beauty
Batteries fully charged. When traveling aprox. 300 feet full speed the batery indicator says the chair is out of power and slows to a crawl. after letting it rest for a few minutes the Indicator says...
Has your power chair been sitting unused for a while? It sounds like your batteries have become damaged and are having problems discharging the power smoothly or may not be taking a full charge.
The batteries contain a gel that needs to have current run through it on a regular basis (at least 8 hours once a week) or it will solidify. If you attach the charger, what will most likely happen is the green light will either stay green or go to green after a very short time. The charger will indicate the batteries are full, but instead of being full of power, they are full of crud. Your warranty will most likely not cover replacment as this is due to customer neglect, but your insurance may still cover the replacement if you can wait for the process to go through. Otherwise, you will need to replace the batteries on your own.
Oct 25, 2010 | Pride Mobility Products New Pride Mobility...
Wheel chair won't move. Batteries have been charging for several hours and have some charge but chair will not move.Any suggestions? Thanks
Romp, Did you check the freewheel levers chair will not move if you are in freewheel. Levers are in front next to seat posts and need to be facing forward. If you are not in freewheel then check the number of lights you have on on the joystick and that they aren't flashing. Also check that your speed control is not on the lowest setting even with some charge a slow speed setting will not let the chair move. Now by some charge you mean lights in the green on the joystick? If the lights aren't flashing then I'm kinda unsure other than even with some charge the batteries don't have enuf current to drive the motors and need to be replaced Hoe this helps
Aug 22, 2010 | Pride Mobility Products New Pride Mobility...
When turning power it makes a clicking sound but does not power up. battery charger has a red and green light on. When plugged in and turned on it flashes 8 times. I checked the power control connection,...
The chair will not move if the charger is plugged in. The flashes are normal with the charger plugged into the chair. The lights on the charger mean that the batteries have been fully charged. Red and yellow lights mean charging. After you unplug the charger from the chair (if off-baord charger, turn charger off or unplug from the wall) then unplug from joystick. after plug is removed from joystick press the on button and all the battery lights should be lit and when you move the joystick forward you will hear the electric bake release and the chair should move forward etc Hope this helps
Aug 10, 2010 | Pride Jazzy Select 6 Indoor Power...
Led lights flash and Pride Go chair won't move.
Firstly disengage the drive levers and then "flick "them in fash.
Second pull out the large plug that is between them.
Check for damaged or bent or loose pins. press it home firmly .
I did this on my wifes chair and she zooms around.
All switched etc should be off during charge.
Lastly i fully discharged then recharged the battery to ensure no "battery charge memory".
To fully dicharge i shoved a small box between back wheels so to lift of ground and then a elastic band to hond controler on.
Jan 11, 2009 | Pride Go Chair Travel Power Chair
Pride Go Chair Travel Power Chair Logo
222 people viewed this question
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
