Yes, press <Aditional Functions> Custom Settings> Audible Tones> select On or Off for each tone. If you are refering to a copier equiped with the fax feature, the process is similar...just in a different area. Hope this helps.
1) you do not dump toner into the drum! Juo dump it into the toner unit. 2) didi you after replacement put the blue toner handle (right from toner unit) into the left position?
turn off copier on the left side lower left to the rear there is a cover with one screw holding it in. remove screw and cover behind it is the waste toner bottle.. Empty bottle then at the top of the bottle is is 2 little circle indents (windows) clean those indents inside and out put bottle back in turn on copier that should do it good luck
