Refrigerators Logo
A
Anonymous Posted on Jun 24, 2010
I have a water line thats cut off and dont know where its supposed to hook up to
Mike Squire
Level 3:
  • Master 420 Answers
  • Posted on Jun 24, 2010
Mike Squire
Master
Level 3:
Answers
420
Questions
Helped
258547
Points
1000
If you are referring to the ice maker water supply it usually connects to the hot water line of the kitchen sink by using a saddle valve like the ones that come in an "ice maker connection kit"
2answers
Unit is 12000 btu and leaking water
it has a hook up on the back,there is supposed to be a plug covering it and also supposed to be able to hook a hose onto it to drain the water,you have to drain them every day or 2
1helpful
Error f20 w/ water coming out hot inlet (not hooked up)
yeah you need to connect the other hose because the mix valve just below that does not seal one or the other..those switches work with the water pressure..thats why the errror showed up..
No instructions came with the dishwasher and i dont know where the water line goes i cant find it
The water line hooks up underneath the dishwasher, it connects to a water valve, usually blue in color. You'll need to make sure the water line is slid underneath the dishwasher, and then make sure the bottom kick-plate is removed from the dishwasher, to do this.
Mar 30, 2010 • Dishwashers
I need to hook up 3/4 cpvc water supply line to water meter
I went to Home Depot for the same reason.Ended up getting a brass fitting with a cpvc insert that excepted the cpvc pipe to be glued into brass fitting once it was screwed in place.Came out about a foot then used a coupler to join both cpvc pipes so in the future I can replace meter without cutting pipe.Im not a plummer just a home owner who cant afford one so I dont know if I did it right but it works.
Reinstalling a washer and dryer and i know which line is hot and which one is cold coming out of the washer ing machine but i dont know which line is hot and which is cold when hooking it back up the the...
If the pipes were installed properly, then the hot is on the left, cold on right.
Hook it up that way, then set it on the smallest load possible, with hot water setting only. If you have hot water filling the basin, you have it hooked up properly.
1helpful
2answers
SHU43C02UC
Dishwashers don't heat water to clean dishes. It is supposed to be hooked to the hot water line, make sure it is the hot water line.
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
