SOURCE: I purchased a LG Dehumidifier
Remove the drain bucket. on the top there are two pieces that can be removed just by taking them out. they are just laying in there. 1 is the brush the other is the "drain tube insert" it is a plastic tube and has a threaded fitting on one end. take your garden hose with a female connector on one end just like you were going to install on your spicket outside of your house and connect it to the threaded end of the "drain tube insert" make sure you knockout the round plastic drain plug cover hole located in the back of the unit (it is behind where your power cord was stored) it has three tabs to break. remove drain bucket. take the drain tube with hose attatched and insert it into the drain plug hole in the back and attach it onto the drain outlet (the drain outlet is inside the drain bucket side at the top it looks like an elbow fitting) push the tube so that the flap with the arrow is flush with the back. once you get the "drain tube insert" almost all the way flush with the back -->if you look inside the drain bucket side you will see where it fits over the drain outlet
SOURCE: I have a Maytag M7DH65B2A. I hooked up a hose to
Had the same problem. Make sure you tighten the house a little with pliers. Also, make sure the dehumidifier is up a lot higher than where you're draining it into. Mine drains into a utility sink. But I have the dehumidifier propped up onto a dresser. I cut a small piece of hose to run into the sink. Seems to be working now.
It will take 5 min or so to establish a water flow, so be patient after you hook everything up. Good luck.
SOURCE: whirlpool dehumidifier drains into the bucket, not the garden hos
I had a sililiar problem. I think I tightened tthe hose after putting a new rubber gasket on hose fitting, Also checked angle of hose.
SOURCE: Trying to use the hose
This may not help because I'm not sure of what you have, but most dehumids when using a hose hook to a fitting on the tank. If that's what you have, before you hook the hose you have to either punch a knockout in the center of the hookup on the tank or cut it out. Hope this helps.
SOURCE: i have a hose discharging water from back . but
The clog is not in the hose. It's in the hose connection tube inside the unit. To unclog it use an 18" long plastic Zip Tie or something similar that is flexible and will fit into the hole. NO wire coat hangers though. Gingerly work it into the hose connection hose, until you reach a bend in the tubing. This is the tricky part, as you have to get past this bend. Be careful and work it past the bend. Once the Zip Tie bottoms out or you run out of Zip Tie, slowly pull it back out while rotating it. This will dislodge the clog. Once the Tie is almost all the way out, be prepared for water to follow.
One other thing. If the unit stops operating check that the bucket full light is illuminated. If it is remove the bucket and empty the contents and then check the seal between the hose and the drip tray. If there is a small leak then replace the hose gasket and re-tighten the hose.
FYI - Your humidifier does not have a pump. It relies entirely on gravity to drain, when you use the hose connection.
That should solve the problem.
Good morning friend, thanks for your post!
Based off what you're explaining it sounds like your Frigidaire dehumidifier might not be leveled. Any time your dehumidifier is not properly leveled water will not drain out the rear but instead into the bucket. I would recommend checking to assure your appliance is leveled. If your dehumidifier is leveled detach the hose to make sure nothing is blocking the water for exiting into the hose. If those steps are unsuccessful and you continue to get water into the bucket please respond back and I can research more information for you. Best of luck. -Matt
