most pairing when asked by the device requires a 00000 passcode but you need to set the jabra and the iphone up for pairing here is a link for jabra the iphone should see it when the jabra is set to set up mode.. http://www.jabra.com/support/Jabra-JOURNEY_100-47300000-15
As you pair the bluetooth in your computer and a bluetooth device, it gives you a pairing code, only if needed so, like the keyboard. The pairing code is seen in the computer, and is generated by the computer as you click on "create a pairing code". For other devices, a pairing code is NOT required.
you need to intorduce again the jabra blutooth to your device. deleting jabra from the list make it forget the connection.
set your jabra to find mode by pressing the poer button for more than 5 seconds wait to blink, and find it using your device. it will again ask for a passcode and it will connect afterward.
Hello. It needs to have the solid light on. That means it's in pairing mode.Make sure there isn't alot of other wireless items near the PS3 at time of pairing. Thanks!
After registering the bluetooth device ( in the settings> accessory settings> register bluetooth device) you must then go to the audio options in the settings >accessory settings >audio options and switch the input from do not use to use to the name of your bluetooth to turn on the connection from the bluetooth to your ps3
