I've tried without success to download the owners manual. Since it's only these 2 things I want to do maybe someone could just tell me. I seem to remember having to hold down 2 or 3 designated keys with one hand whilst using the other to press certain keys for the adjustment. There's no way I can remember and I can't find the book.
Can anyone help? Much appreciated.
Mike
SOURCE: I have a Roland HP 101 digital piano however certain dont sound
White spirit is NOT what you should use. Mineral spirit leaves a residue film.
Use 99% isoprophyl alcohol.
ALSO inspect the contactboard for cracks by candeling with bright light behind it.
Testimonial: "bur isnt it strange that certain keys have stopped working? ie most the A keys"
SOURCE: Does anyone know where I can find an owners manual
This is the only thing I could find unfortunately:http://www.yamaha.com/yamahavgn/CDA/ContentDetail/Text_WithCatMenu_XC.html?CNTID=554234# Have you tried contacting them?
SOURCE: Hello! I'm using a Yamaha P85
Hi, what causes clattering sound in key boards are when the rubbers inside the key board are getting weak and it needs to be replaced.It's not a normal thing.
Secondly, The idea ofdisassemblythe keyboard is a Good idea ,but i would not advice you to do that,cause keyboard issues are very delicate and fragile to handle..
finding parts out, i will give you links to guide you.
http://www.computerhope.com/comp/yamaha.htm
Contact the above link they will link you up to their company in Sweden if there is any..
Good luck..
SOURCE: I Just bought Yamaha MM6,
Usually that is a programed feature, but you can try the support center at the manufactures website.
SOURCE: I'm using a Yamaha FC7
you CANNOT do this connection!!! Period !!! It will not work electronically The keyboards are fighting eachother as each is driving audio into the WYE. If you want to control both levels you need to use a controller that has two separate controls. At one point such a device was made but not sure if they still are... Here is a candidate:
http://www.google.com/products/catalog?hl=en&q=volume+pedal+dual&rlz=1R2ADFA_enUS400&gs_upl=4797l11703l0l12063l17l14l0l1l1l0l1031l4813l0.1.6.3.6-1.1l12l0&bav=on.2,or.r_gc.r_pw.&biw=1203&bih=624&wrapid=tlif131583417165610&um=1&ie=UTF-8&tbm=shop&cid=16799990617547769868&sa=X&ei=RQluTpqgO4fXiAKV09W8Dg&ved=0CCUQ8wIwAQ#
