Can you offer any help on how to remove the old transfer belt and install the new one? The system pulls apart in the middle - but don't see any latches etc. to perform this function. Mark 886-800-8180
Transfer belt on this model is removed via left and right side of the machine two screws on the right side remove then the belt is pulled from the left side
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
SOURCE: I can't print from IMac to konica-minolta buzhub C350
Go to konicaminolta web site and download a mac driver. and install it to Imac. Make sure to download OS10.4 or higher.
SOURCE: how do we change the language on the konica minolta bizhub c351
1) Press "Utility-User Setting-Language Selection
2) Go to service mode System 1 - Marketing Area - US
You have to do both
SOURCE: SERVICE CALL 14 XFER ROLLER
the transfer roller is a foam roller that transfers the toner onto the paper. It will be visible with toner removed, a little wider than a piece of paper, and about the thickness of a roll of quarters. I don't know how to physically remove it on your model, but transfer roller issues in general can be remedied by removing the transfer roller and wrapping it in packing tape until the tape comes off clean.
While you're in there, vacuum everything out for good measure; but never, ever use canned air on a laser printer.
SOURCE: i have a konica minolta bizhub c351 How do I
select "PDF"- MMH option, not the "MMR" option from one touch menu.......
