How do you turn the passenger seat around on a 1986 VW Westfalia camper?
There is a small round metal wire that comes out of the front center of the seat. If you sit on the seat, while depressing the wire down, and pivot using your body weight, the seat should turn. Sometimes spraying the black seat mount is necessary to lube it. You may have to remove the seat if rusty or very dirty. To do that, slide the seat as far forward as possible, then lift the small metal lever on the left side of the seat, to release the lock on the track allowing the seat to move forward off the track. Note: both the passenger and drivers seats should turn on your model.
