Magic MCB770W 700 Watts Microwave Oven Logo
Posted on Jun 23, 2010
No power at all. Outlet is fine. Is there an internal fuse?
dreeme1
Level 1:
  • Contributor 36 Answers
  • Posted on Feb 28, 2015
dreeme1
Contributor
Level 1:
Answers
36
Questions
Helped
13802
Points
77
Yes there is most of the time. A new fuse can be obtained from radio shack. Most ovens use a small ceramic cartridge fuse ABC 15 or ABC 20. Please note though that this fuse usually blows because one of the small microswitches in the door circuit is bad (overheated and is burning up inside) or has operated out of sequence with the other several switches. Newer microwaves have one big switch assembly that needs to be replaced when the fuse blows. Make sure the door fully closes when replacing a switch. Be very careful with microwaves. There is very high voltage inside that could severely shock you!
Unit went dead. No fan, display, light, oven. Is there an internal fuse or reset?
There is an internal fuse. Be careful high voltages present even if the microwave is unpluged.
Good luck
My LG over the range microwave and vent stopped working. The outlet it's plugged into is fine.
it may be an internal fuse that popped. try a lamp or something in the outlet. if that's ok, it's probably a fuse inside the microwave.
Where is the internal fuse in a samsung SMH1816S
I had a bad thermal fuse / thermostat and posted the repair video.
https://youtu.be/xqidYkMglqw
Thank you to all the people that have posted repair videos! I use them every time I have an appliance break!
The microwave does not react what so ever. Checked the fuse and its fine, what could be the problem? please help
Is there power at the outlet? You say you checked the fuse ... is that the one inside the machine? Is the outlet protected by a GFI (reset for a GFI is on the GFI)? A GFI looks like a ordinary outlet but is very sensitive to electrical irregularities. Your circuit breaker may be on or your power panel fuse may be fine and the fuse inside your oven may be fine. If the GFI is popped, you have no power.
Try some other electrical device in the outlet. Does it work? Try an extension cord from a known hot outlet?
Beyond these tips, you may need professional help with this.
Thanks for your interest in FixYa.com
2helpful
2answers
Went to use and there was no power in unit. was
my kenmore 565 has gone out...no power. We have checked the power supply works. Can we check the internal fuse?
Oven won't work. Fuse is fine and so is outlet.
if the unit has no internal fuse that has failed, check/replace the capacitor that connects to the magnatron
No power to microwave, changed fuse but still nothing!
There is an internal fuse and internal TCOs (thermal cutouts / thermostats) any of which can interrupt the power to the unit.
Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
GE Customer Service is here.
They can help you find your
your nearest GE-authorized servicer.
Top Magic Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Magic Microwave Oven Expert? Answer questions, earn points and help others
