The F11 code is caused by either a CCU failure or an MCU failure...here\'s how to tell:
If your machine starts a cycle and the water fills but the drum NEVER turns, your MCU is bad...it\'s most cost effective to buy a refurbished one and you can get them on eBay for $99 all day long.
If your machine makes it most of the way through a cycle but throws an F11 code during the rinse or spin, your CCU has the relay solder / vibration problem...
Hi, The F11 fault is actually described in the tech sheet as a "Serial
Communication Fault" involving the MCU (the washers computer) and the
DC Drive assembly that runs the motor. If you are not familiar with a
DC drive, it is simply a controller for the motor that varies the
voltage to the motor to change speeds. This is so the washer can crawl
slowly to tumble your clothes as well as spin at the ridiculously high
speeds using the same motor. I would argue that "Jay's" is wrong about
the door latch - there is a different specific code for that
malfunction (I think it flashes F and DL). I wish it was the door lock
- that's cheap, unfortunately, I think you are in for a MCU @ ~$200.
Take care
