Hello:
I hope the following information is helpful.
If you are trying to install the driver for the Broadcom ethernet NIC that was pre-installed (NOT an ethernet card that you purchased and installed yourself), there is a softpack (updated driver installation) download available from HP/Compaq. It will install the driver automatically for you, just download it from the link below and run the ".exe" file.
IMPORTANT:
Check to be sure that your current Operating System, and model of the network device you are trying to install, are BOTH listed below BEFORE you download!
This is a software / driver update for the HP Compaq d530 ultra-slim desktop: All Models
Supported network devices:
BCM5906M
Broadcom 10/100/1000 5782 based NIC
Broadcom 570x 10/100 Integrated controller
Broadcom NetXtreme Gigabit Ethernet 5782
Broadcom NetXtreme Gigabit Ethernet PCI-Express
NetXtreme(tm) 10/100/1000 Gb NIC
Supported Operating Systems:
Microsoft Windows 2000
Microsoft Windows 98
Microsoft Windows NT 4.0
Microsoft Windows Vista Business 32 Edition
Microsoft Windows Vista Business 64 Edition
Microsoft Windows Vista Enterprise 32 Edition
Microsoft Windows Vista Enterprise 64 Edition
Microsoft Windows Vista Home Basic 32 Edition
Microsoft Windows Vista Home Basic 64 Edition
Microsoft Windows Vista Home Premium 32 Edition
Microsoft Windows Vista Home Premium 64 Edition
Microsoft Windows Vista Starter 32 Edition
Microsoft Windows Vista Ultimate 32 Edition
Microsoft Windows Vista Ultimate 64 Edition
Microsoft Windows XP Home Edition
Microsoft Windows XP Professional
Microsoft Windows XP Professional x64 EditionINSTALLATION INSTRUCTIONS:
1. Download the file by clicking the "Download" or "Obtain Software" button and
saving the file to a folder on your hard drive (make a note of the folder where
the downloaded file is saved).
2. Double-click the downloaded file and follow the on-screen instructions.LINK where file can be downloaded:HP/Compaq Support-Broadcom Driver download
Again, I hope this information is what you neededto install your network device. Should this not answer your question, please come back, provide more details of your problem, and we will be happy to help!Best of luck to you!
SOURCE: I just cannot find the model name of my ethernet controller for my HP Compaq D530 Sff.
Hi there.
You don't need the model number of the ethernet controller itself, you have already provided the information i need to help you (the computer make and model).
Go here to HP support, choose your operating system (win2000, XP etc) download and install the LAN (network) driver >>>>>>
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=uk&prodNameId=316715&taskId=135&prodTypeId=12454&prodSeriesId=316713&submit.y=0&submit.x=0&lang=en&cc=uk&y=0&x=0
Good luck and thanks for choosing FixYa!!
SOURCE: Ethernet controller not installed on XP Professional
The best way to get the drivers you need is to go to www.hp.com and search for your drivers there using the model number for your computer. Of course, this assumes that you can get internet access from somewhere else besides the computer that you are working on. If you don't have another place you can get on the internet, try your local library. Many of those have free internet access. In my experience, the most likely driver for your computer would be either the Broadcom Netextreme or the Intel Gigabit driver. Good Luck & thanks for using Fixya
SOURCE: ethernet driver for hp compaq d530
Drivers are located here: http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=316715&lang=en&cc=us&prodTypeId=12454&prodSeriesId=316713&taskId=135
You must select the appropriate operating system for your application
SOURCE: Ineed hp compaq d530 driver
The driver is available on the HP website. I believe it's a broadbent The PCI SFF modem should be easy to come by. Try this link:
http://www.pcliquidations.com/item.asp?id=3694&referid=160164167166161
$20 bucks.
Your ethernet board is a Broadcom. Here's the link and just select your operating system:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=316715&prodTypeId=12454&prodSeriesId=316713&swLang=13&taskId=135&swEnvOID=1093#11395
Hopefully the entire link will work...but if you go to hp.com, go to the support section and type in your model number and you'll find it.
SOURCE: i have failed to install ethernet driver after
your operating system should detect and install the drivers for your network controller if it is an internal on board LAN. however you must be sure that you have the LAN enabled in your BIOS setup under the advanced selection on the bios screen. otherwise , your operating system won't even see that you have a LAN connection.
Here is the HP site and Driver page for your PC.
Hope this helps!
