Question about Canon PowerShot SD600 Digital Camera
How can I turn off auto flash in my canon sd 600 camera?
  • Anonymous Jun 22, 2010
    Thanks for the reply.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
Press the flash button (right-arrow on the control panel, marked with a lightning bolt) repeatedly to cycle through the flash settings. To turn the flash off, select Off, marked by a lightning bolt in a circle with a slash through it.
Don't forget to turn it back on when you're done.
Posted on Jun 22, 2010
6ya staff
SOURCE:
How to format an SD card on a Canon SD600 camera when the menu says "memory card locked." The memory card is in the unlocked position. When we put the SD card in another Canon camera (SD780 IS), it works...
Could be that you have the wrong memory card.
SD600 will only work with the old SD cards, but the SD780 will take the SDHC cards.
SDHC was intended to give 4gb or more of storage, while the old SD started as 16 mb.  Different cameras have different limits, but it is always best to assume that the practical limit on an SD card is 2mb.  Even if the SD780 will take the SDHC cards, it can be more practical to only carry 2GB SD cards and know that they will fit either camera
Feb 22, 2010 | Canon PowerShot SD600 Digital Camera
Can i turn the flash off on my camra and if yes how. I bought the cara off a friend and she the booklet that came with it dont know any thing about this canon 600
To turn the flash off, press the right side of the ring shaped controller on the back of the camera where you see a lightning bolt icon. Each time you press it, you will see an icon pop up for a different option -- Auto (bolt with A), Auto with red eye reduction (icon of an eye), red eye reduction with flash on (eye and lightning bolt), On (just the lightning bolt), and Off (bolt with a "no" circle around it).
You can download the manuals (Basic and Advanced) for the SD600 here. I understand that there is a problem with the downloads that should be repaired within the next couple of days. If you want a manual sooner, you can download the manual for the European version of this camera (IXUS 60) here.
Feb 08, 2010 | Canon PowerShot SD600 Digital Camera
How do i turn my flash off canon eos xsi
In your camer there will be seven Full Auto modes : full auto, portrait,
landscape, close-up, sports, night portrait and FLASH OFF. Turn
the Mode Dial of the camera clockwise as far as it will go to
disable the flash. In Full Auto, the flash is also disabled in
landscape mode and sports mode.
Hope this helps.
Jan 24, 2010 | Canon EOS Rebel XSi Digital Camera
When turn on, lens won't extend-error message Canon SD 600 digita
Problem: dust in the gaps near lens which makes it jammed. Effect: the sceen shows blk color. Solution: just blow over it or vaccum it.
Oct 10, 2009 | Canon PowerShot SD600 Digital Camera
My sb 600 fires with the camera but it seems not illuminate
Definately a settings problem. The camera will only syncronize on one specific speed. Youe best bet is to use auto. For manual, you'll have to set the shutter speed at the sync speed.
Flash Sync Speed
  • up to 1/250 X-Sync Speed
  • up to 1/8000 FP High Speed Sync
  • Red-eye reduction
    Red-eye reduction with slow sync
    Rear-curtain sync
    Slow sync
    Front-curtain sync (normal) Flash Sync Modes
  • 1) i-TTL: TTL flash control by 1,005-pixel RGB sensor, built-in flash, SB-800, SB-600, SB-400: i-TTL balanced fill-flash and standard i-TTL flash
    2) AA (Auto Aperture-type) flash: Available with SB-800 used with CPU lens
    3) Non-TTL Auto: Available with Speedlights such as SB-800, 28, 27, and 22S
    4) Range-priority manual flash; available with SB-800 Flash Control
  • Mar 13, 2009 | Nikon Speedlight SB-600 TTL Flash
    Memory Disk Full
    SD card slider on the side in the "locked" position?
    Its the overwrite protection for the SD memory card.
    -Suf
    Jul 27, 2008 | Canon PowerShot SD600 Digital Camera
    Need to download software for canon powershot sd 600
    If you plug in your camera via USB to any computer, you should be able to access the card in the camera and transfer the files to the MY PICTURES location. You can also download Picasa which will do the same thing.
    If you must use the software that came with the camera here is the site:
    http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=224&modelid=12913#DownloadDetailAct
    Jul 24, 2008 | Canon PowerShot SD600 Digital Camera
    Canon sd 600 auto focus is not working
    You should first check if the Lens of the Canon PowerShot SD630 Camera is clean,then check if it is the GPU problem.
    Jul 22, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
    Cannon Powershot SD 870
    you can change it to no flash by when your taking a picture press the right arrow
    Jul 01, 2008 | Canon PowerShot SD870 IS Digital Camera
    Canon SD 550 does not work when flash setting is ON
    I have the same problem. Cannon customer support says it will fix this for $119 + 8 for shipping... or you can get a refurbished SD 800is for $140+10 for shipping with w/ a 6 month warranty... what a deal ;~)
    Sep 04, 2007 | Canon PowerShot SD550 / IXUS 750 Digital...
    Canon PowerShot SD600 Digital Camera Logo
    218 people viewed this question
    Top Canon Cameras Experts
    old marine
    old marine
    Ekse
    Poul Brinchs Larsen
    Are you a Canon Camera Expert? Answer questions, earn points and help others
