GE JVM1650 1000 Watts Microwave Oven Logo
Posted on Jun 22, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Microwave runs but does not heat - GE JVM1650 1000 Watts Microwave Oven
Anonymous
Level 3:
  • GE Master 43,501 Answers
  • Posted on Sep 30, 2010
Anonymous
GE Master
Level 3:
Answers
43501
Questions
0
Helped
10844559
Points
101584
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
7s7t
My microwave over just stopped heating but runs like it is heating
hi , now that's either power supply to power the magnetron or the magnetron itself ...
Regards
Rob
2helpful
Microwave runs but doe not heat
follow this test and fix it. God bless you
  1. Check the power diode This electronic component is responsible for transmitting current in one direction. If the diode becomes defective it will cause your microwave to not heat. Test the diode and replace it if necessary.
  2. High voltage capacitor Responsible for storing electricity, this part is a key component in any microwave. Remove, discharge, and test the capacitor to determine if it requires replacement.
  3. Damaged magnetron Responsible for generating waves and producing heat. When your microwave is no longer heating properly, replacement will be required.
  4. Thermal Cutoffs Examine the thermal cutoffs on both the magnetron and the oven itself. Take off one of the leads and using a volt-ohm meter on RX1, check the terminals. If you get a result other than zero, replace the thermal cutoffs.
Sharp r-610dk microwave runs but don't heat up
The magnetron has failed, or the inverter board, "if 7 years old or less" there is also a possibility the keypad control board may be the problem.
1helpful
2answers
Microwave runs but doesn't heat
Most likely shorted the transformer for the magnatron,Its expensive to repair and you should consider just replacing the micro.
Magic Chef Microwave runs but no heat produced,
heatman101
uitot
The microwave runs but doesn't heat?
heatman101
jke
Microwave runs but will not heat
heatman101
jhj
Microwave will not heat
Q - The microwave makes a loud "hum or buzz" noise but will not heat up the food?
A - 9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section.
Q - My microwave is running and sounds like it is working but will not heat up anything.
A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
 Q - The microwave display counts down and the inside light is on,  but nothing is heating and the fan is not running.
A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
Q - The fan in my microwave oven is not running will this hurt my microwave?
A - YES, the fan cools the magnetron and electronics, take the microwave in for service, most fans are not too expensive to replace.
Q - My microwave blows the fuse inside itself as soon as I push the start button.
A - Usually a shorted high voltage capacitor...see components section.
4helpful
2answers
Runs but won't heat
Does the turn table and interior light come on?
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
