Have same problem with grill smoking,try barry coates method if this works to stop from happening again there should be a tray that comes with most ovens,flip this over and put on top rack,should stop this problem,then place foil on bottom of oven to catch any spills or buy another tray.. all the best tony gilchrist....
SOURCE: cleaning above the grill element
I would not advise you to remove the element unless you feel competent to do so.
Best thing to do is to put the grill full on and let all the fat and grease burn itself off.
you will not hurt anything by doing this.
Make sure you have the griil door open and your house door.
Plz rate my solution.
thanks.
SOURCE: when my oven is on
The element will clean itself. Leave it red hot for a few minutes. and let the smoke clear.
It will be clean.
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
SOURCE: replacing electrolux eob944 fan oven grill element
...If you can help me to remove the grill element from my EOB944, I will be able to tell you the wirings.
SOURCE: i have a delonghi oven.
no you dont need a new grill its just collecting fats from when you roasting and burning off when you initially heat the grill. if you use the grill more often it wont build up as much. covering the roast can reduce the saturation and perhaps a slightly lower temp will help reduce splattering.
SOURCE: belling 492ss multifunction oven and
Hi you have a definite short , it could be a bad element or a wire that has burned though and is touching metal, turn off main power and start taking this unit apart, i would start with the grill since this is giving you the problem, http://www.appliancepartspros.com/ this place has almost every part i have ever needed and they ship same day you can also email me @ [email protected] good luck !
