Olympus EVOLT E-500 Digital Camera Logo
A
Anonymous Posted on Jun 22, 2010
I am trying to get my camera back to the factory settings but everytime i go menucardset then go tocustom reset setting it jumps over it and goes straight to picture mode. I cannot get it to highlight custom reset setting.
Anonymous
Level 3:
Brigadier General:
  • Master 11,967 Answers
  • Posted on Jun 22, 2010
Anonymous
Master
Level 3:
Brigadier General:
Answers
11967
Questions
0
Helped
2200784
Points
38521
There may be another "reset" in the menu that will do what you want. Search for it.
1helpful
2answers
When I push '-' to make image smaller screen goes black
Check your setting in "Custom Functions". Sounds like your "-" (or more specifically your "*" button) has had a feature enabled. I had my "*" button set for focusing - under Focus Settings in Customs Functions. If in doubt reset all Custom Functions to their default.
2answers
Settings Reset
DId you try reseting it by removing the battery and memory card?
I have sony DSC-W190,i want correct menu setting ,bcos if i take a picture its not clear,i think may be menu setting changed,idnt any idea about menu setting pls help.....
If the Menu settings in the camera is changed, then I suggest you to reset the Camera back to factory default. Initializing the Camera back to factory default will set all the settings in the Camera back to factory default.
To initialize the Camera back to factory default, select the INITIALIZE Option from the Main Settings 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
You can also try a manual reset;
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
The blurry image capturing can also adjusted by changing the ISO Settings or the Scene Selection modes.
Thanks for using FixYa!
Everytime i turn off the tv and turn it back on
Tries unplug,replug 1 hour later,tv should reset itself to factory setting.
How do u reset temp,everytime i set it to 63 it
I think you will find that when you set the temperature, you are setting it to its lowest or ideal setting for you. When it jumps back its jumping to the temperature within its own guage reading, ie the second temperature is what it is at the moment. then it endeavers to lower that temperature to the one set by yourself. if you run the machine and keep an eye on it you should find that "jumped back" reading slowly reducing. I hope that helps(its what i,ve found anyway)
1helpful
Fuzzy pictures
It's possible that some of the settings are set improperly on the camera. Try resetting the camera back to factory default settings and see if this makes any difference. To reset the camera - have the camera in shooting mode - go to Menu - left arrow to RESET - press Ok - highlight Yes and press Ok. This will set the camera back to factory settings. Try to take some images and see if they are still fuzzy.
2answers
Help me desperatly
reset the factory settings...and replace the cells.....sud be wrking fyn after resetting to default factory settings..
2answers
Camera
when u go to ur camera mode try takin ur memory card out see if that solves it failing that reset ur fones memory by going to reset factory settings the pin should be 00000000 or 11111111 any more advice dont hestitate to ask
Top Olympus Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an Olympus Camera Expert? Answer questions, earn points and help others
