Nokia 5530 XpressMusic Smartphone Logo
Anonymous Posted on Jun 22, 2010
I HAVE NOKIA 5530 XM. IT CANNOTSEND TEXT MESSAGES. WHEN I PUT MY SIM IN ANOTHER PHONE , IT SENDS MESSAGES, MEANS THE SIM IS FINE, AND WHEN I PUT ANY OTHER SIM IN MY NOKIA 5530 IT SENDS MESSAGES, MEANS THE PHONE IS OK. BUT, THE COMBINATION OF MY PHONE AND MY SIM DOES NOT SEND MESSAGES, WHY? I HAVE TRIED EVERYTHING, CONFIRMES SMS CENTRE NO. , CLEAN UP THE SIM , CHANGES CONTACTS NO. ETC. BUT NOTHING SEEMS TO WORK. WHENEVER I SEND A MSG IT GOESINTO OUTBOX, AND SHOWS A MSG THAT " UNABLE TO SEND MESSAGE". PLZ HELP
Anonymous
Level 2:
  • Expert 111 Answers
  • Posted on Jun 22, 2010
Anonymous
Expert
Level 2:
Answers
111
Questions
0
Helped
80477
Points
251
Nice noon...you need go to cellphone repair shop anf try to reprogram or master reset your phone,,i think the problem of your phone is software..good luck....
  • jojobautista Jan 16, 2011
    repair shop will just input a code for that to work, I think giving that code would really help every body, repair chop will just charged for this code, any body knows this code?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on May 21, 2012
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
517
Points
0
Ineed help with my Nokia 5530 xpressmusic it don't have network plz IMEI: 354200/03/592657/3 thank you.
Anonymous
Level 2:
Sniper:
  • Expert 58 Answers
  • Posted on Nov 17, 2011
Anonymous
Expert
Level 2:
Sniper:
Answers
58
Questions
0
Helped
26407
Points
192
Try the default code 12345,restore factory settings.
if the code is error again,we need to go to cellphone repair,wer
do we like it or not..
1helpful
Unlock code nokia xpressmusic 5530
Get the unlocking code for your Nokia 5530 xpress music from http://www.simpleunlocking.com/ .This is the online service provider which offer the service for your mobile.After getting the code, follow the instructions here,
1 - Switch on your Nokia 5530 Xpress music without any sim card.
2 - Don't bother as to what is displayed on your Nokia 5530 Xpress music.
3 - Compose
#pw+CODE+1#.
4 - The Nokia 5530 Xpress music would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 5530 Xpress music mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose
#pw+CODE+7#.
Nokia 5530 cannot send text messages
Check if your Message Center is correctly configured: Go to Messages, press Options, go to Settings, Text Messages and then Message Centers.
I cannot send text messages with my nokia 5530 cellular phone
Take the battery out and let it sit for 10-15 seconds. Put the battery back in and power up. Try to send again.
2answers
Need to enter unlock code for nokia 5530
Follow the Unlocking instructions Below and Enter the Nokia 5530 model mobile.......
Nokia 5530 Xpress music Unlocking Instructions:Warning : Do not enter any wrong unlock codes on your Nokia 5530 Xpress music mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia 5530 Xpress music mobile phone, your phone may get hard locked and sometimes become unusable.
3 - Compose #pw+CODE+1#.
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 5530 Xpress music
You can get the Unlock code and Instructions here
http://www.theunlockarena.com/nokia-5530-xpress-music/rs13wp9/
Nov 11, 2010 • Cell Phones
2helpful
I have a nokia 5530 xpress music and i cant send picture messages, i had to rest to factory settings recently because i couldnt send text messages! I've looked at the settings and they are no different to...
Hard reset your phone. This will delete all the content of your phone so remove your memory card before resetting your phone. On the home screen type *#7370# .
I cant send my 5530
for sending text messages :
1. call to your network operator customer care
2. request the message center number...
3.note it down
4. go to message settings>message center number
5. insert the number which is noted by you and save it
this solves your messaging problem ...
Good luck
1helpful
I cant send a message on my nokia 5530..but i can recieve messages..what should i do?
in message settings...
under the option of sent message via, select it by "text"
and under option reply via same centre, select it "no"
1helpful
CANT SEND MESSAGES
Your phone is fine.
You need a new sim.
Older sims aren't up to the demands of newer handsets anymore so they brought out more powerful and higher voltage sims.
Go to your local mobile phone shop and explain your problem to them and they should be able to sort you out a new sim. :)
2helpful
N5530 -Cannot send and receive text messages
Switch-off your phone. 1. Press and hold 3
keys; Green dial key, *
Star key, no. 3 key on keypad and then press
the power on/off to
swtich on the phone. Remember, do not let go the 3
press and hold
keys until you see a formatting word screen show! 2.
After a few
minutes when the Full phone formatting completed, your phone
will
back to original system and factory settting.
I can not recieve or send text messages when i try it goes straight to outbox , how can i fix this??
hi there,
call the customer service of your service provider ( AT&T,Vodafone,Verizon etc)....they will set up message center number on your phone , the one that you have might be incorrect...your mobile operator will send you sim updates that will refresh the settings ....and then you will get the text message options
cheers
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
