Nokia N95 Cellular Phone Logo
Posted on Jun 22, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Internal loudspeaker doesn't work - Nokia N95 Cellular Phone
Anonymous
Level 2:
  • Expert 111 Answers
  • Posted on Jun 22, 2010
Anonymous
Expert
Level 2:
Answers
111
Questions
0
Helped
80467
Points
251
Hi ! nice day ! i thinkyou have need to clean or replace the buzzer of your n95 mobile phone...good luck,,
How do I connects my lg phone to the loudspeaker
If you mean to the internal speaker, there should be a speaker symbol when making or receiving a call, which you press to activate.
If external loudspeaker, you can patch your earphone out socket to the line-in of your hi-fi / amplifier.
Do not connect an external loudspeaker directly to the phone - this will damage the phone.
If your amp /speaker / soundbar has bluetooth / Wi-Fi capable of pairing with your phone, then switch on both devices and pair them.
How do you remove the passenger side rear door panel in a 2006 Fiat Punto
1 Prise out the trim cap and undo the screw securing the exterior mirror inner trim panel of door
2 Where a manually-adjustable exterior mirror is fitted, prise the rubber cover off the adjustment lever, then unscrew and remove the locking collar using pointed-nose pliers.
3 Pull the panel from its location to disengage the retaining clips. Disconnect the loudspeaker wiring connector and remove the panel.
4 Lift off the trim caps, undo the retaining screws, then remove the door interior handle surround.
5 Carefully prise off the loudspeaker grille then undo the three loudspeaker retaining screws. Withdraw the speaker from the door and disconnect the wiring connectors.
6 Undo the three retaining screws in the loudspeaker aperture, and the single screw in the oddments pocket just below the aperture.
7 Lift out the loudspeaker protective cover and withdraw the loudspeaker wiring from the base of the cover.
8 Prise out the trim cap and undo the screw securing the rear of the trim panel to the door frame of Fiat Punto car.
9 Undo the screw at the upper front corner of the panel, and the remaining four screws securing the lower edge of the panel to the door frame.
10 Using a suitable forked tool inserted between the door and the trim panel of Fiat Punto, release the press-stud clips located around the edge of the panel, then lift the trim panel upward.
11 Pull the panel from the door, noting that the lower window aperture weatherstrip is integral with the trim panel and must be released from tie door as the panel is withdrawn.
12 If work is to be carried out on the door internal components, it will be necessary to remove the plastic sealing sheet from the inside of the door. Start at one comer of the sheet and carefully peel it away, using a sharp blade to split the sealant bead, if necessary.
13 Store the detached sealing sheet such that it cannot become contaminated with dust; this will allow it to be re-used later.
Source (with illustrations) - Door inner trim panel removal and refitting FIAT Punto
No sound from loudspeakers or headphone from my Yamaha
You shouldn't b listening to music while riding a yamaha dumb f*ck
Cant hear incoming calls its ok if i switch on loudspeaker
It seems that your phones internal speaker is not working. You should get it replaced. But for the time being, yes you can use the loud speaker.
I have two Behringer Eurolive B415DSP speaker, one of them stopped working out of no where. To my best knowledge, the problem is that it doesn't turn on. I had the Fuse check already and thats not the...
This is alimentation fault of the amplifier inside the box. Dismount the amplifier block and take a look first if there are some burned pieces. If it seems all ok, better bring it to a electronics/ tv service center.
My microphone does not work, internal or external. Aspire5004wlmi
Right hand click on the loudspeaker icon and select "recording devices"
Check the volume in turned up.
Hope that helps.
Red light flashes - will not work - could it be dust in the amp?
hi,
its not because of dust. AZUR 640A offers loudspeaker protection if the output of the amplifier goes to a high constant voltage (DC) because of some internal fault. This is a rare fault although detecting it could just save those expensive loudspeakers.
Due to the necessary sensitivity of the DC protection circuit, hard clipping of the amplifier may cause DC protection to be triggered. If this fault occurs switch the unit off, power up again and check
operation with a reduced volume level. If the DC fault occurs again contact your dealer for service.
ok
My phone nokia 5130, it doesn't work at this time. But on the following days i can use with loudspeaker only now it doesn;t work
hi :) u mean before u can use with loudspeaker,mean the speaker hearing people talking cant work ?? if now both speaker cant work,mean both speaker was apoil.pls send to mobile shop exchange new speaker.
2answers
Hp hw6515d no sound loudspeaker
Hi, Antonio--
This appears to be common with the 6515. You will either have to get your headphone jack replaced, or you can try what finally worked for me. Insert and remove your headphone jack as many times as necessary to get the internal connector in the jack to work properly.
It took me about a dozen tries, doing it both fast and slowly.
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
