The touch pad might be faulty. Try to reboot the laptop after cleaning touch pad with a clean damp cloth. If nothing happens then the sensors under the touch pad could be faulty.
<p><span>The touchpad of your laptop is a most important and frequently used input device. If your touchpad stops functioning, it may be difficult for you to use your laptop. Touchpad normally faces following issues. <br /><br /><b>Laptop Problems and Their Solutions</b><br /><br /><b>Problems with the driver</b><br /><br />Computer hardware communicates with your computer through real time software called driver. Drivers control computer hardware. It is possible that virus or human activity may damage the driver. You can check your driver's status through computer's device manager. You'll see a yellow color indication under "Mouse and other pointing devices" heading. You can download new driver form your laptop's manufacturer website. <br /><br /><b>Problems with connection</b><br /><br />Touchpad's connection with motherboard is delicate. It can be broken due to heating and other inner problems. So, if there is no problem with the driver, then the connection of the touchpad to the motherboard may have broken. <br /><br /><b>Misuse</b><br /><br />Touchpad of the laptop is the most delicate input device. Some people tap on it too hard or use a shrill tool as an alternative of a finger. This can damage the pad. <br /><br /><b>Fn Keys</b><br /><br />Touchpad driver is slightly different from the other devices that need drivers to function properly. It came with an operating system that you don't need to re-install it. Laptop keyboard comes with many functions than the common keyboard. It has Fn keys which are called function keys. Sometimes, your laptop's touchpad stops working because you accidentally hit some one of the Fn keys. You can follow these instructions to make your laptop touchpad working again. <br /><br />1- Search for Fn key on your laptop keyboard. It is commonly located next to the Ctrl key. <br />2- Now search for F1 to F12 keys on the laptop keyboard. These keys control sound, brightness of the screen, wifi etc. They are located on top of the keyboard. Look for the key which has icon on it that looks similar to the touchpad. <br />3- Let's take an example of Toshiba laptop. It uses F10 key to enable or disable touch-pad. Hold down Fn key along with F10 key to enable the laptop touch-pad. <br /><br /><b>Cleaning the laptop touch-pad</b><br /><br />It is a good practice to clean your laptop touchpad. To clean it, take a cloth dampened with sprit. Wipe your touchpad off with that cloth. <br />Laptop touchpad work best in moderate temperature and gasping environment. Moisture, excessive heat, can damage it. Try using your laptop with tidy hands. Sweaty and dirty hands can cause problems. <br /><br /></span><span><span> </span></span><br /><span><br />
</span>
First of all try to clean your touch pad with a SOFT CLOTH gently soaked in a GLASS CLEANER fluid. Make that as good as you can and you will remove all the dirst that may occur during the function of your computer, generating "fake movements" of the cursor. Second: go to START > CONTROL PANEL > MOUSE icon > DEVICE SETTINGS and disable touch pad or check box to hide cursor while you are typing.
If there is grease from fingers on the touch pad, that can cause spurious movement of the mouse pointer. Clean the touch pad with an almost dry cloth and clean washing up water.
It most likely has something conductive around the edges. Clean the pad with a cloth or paper towel that has 99% isopropyl alcohol on it. Use something like a toothpick to push the cloth or paper right into the edges. Once it is clean, and completely dry, try again. If it still doesn't work you may need to check the connection inside the laptop.
(1) If you are using a laptop for typing text and your cursor is jumping around while you are working with a touch pad then it is a common defect in many Laptops. The solution to this is that you disable the touch pad by pressing down Fn key and selecting the appropriate Function key. You have to use a mouse. (2) If you are using a desktop and the cursor is jumping then it is a very high probability that you have a virus in your computer. Take a updated virus cleaner/remover and scan/clean your system.
Hi!!
Try unplugging unit from the wall outlet for 5 min. If the key pad still do not respond, it may have become defective they are not fixable. Replacing the key pad it is often more expensive then buying a new unit.
Spills and directly spraying cleaner solutions into keypad will eventually cause it to fail.
The correct way to clean the front of your microwave is to apply a small amount of the cleaner solution to a cleaning cloth and then wipe the keypad clean
Show your appreciation with a 4 THUMBS Rating for answering your FREE question. Thank you for using FixYa
