Year and half old rca 32" tv screen goes whitethere is still sound. I shut it off for a few minutes then it is fine for alittle while.
  • 178 Answers
It is defective t-con board or LVDS cable, if you provide the brand, model & version number. may be I can tell you what exactly wrong.
Posted on Jun 22, 2010
6ya staff
SOURCE:
L32W961 screen goes black then comes back on. later when video comes back sound does not
That is definitely a manufacturers error.
If it has been less than a year since you purchased it i would contact them.
They will send you to a service center. If it cant be fixed they will replace your tv.
It is all covered by them.
If it is past a year its honestly not worth fixing it,
You can find name brand 32 inch tv's for less than 250
while fixing it would cost around 150.
Mar 30, 2014 | Envision L32W761 32 in. LCD TV
"32" rca tv about 3 years old was on & it went black- power light is on"
sounds like the sceen is dead, if you are receiving nothing on screen, then it sounds like either a component and/or screen is gone... however, check the tv input to make sure it wasnt acidentally switched to an input channel with nothing selected... if that does not work, call local tv repair or mfg customer service tech. if under warranty, have repaired or replaced. without physically seeing tv, it is hard to diagnose issue outside of information given. could be simple board replacement or could be screen.. but check input first, if a dvd player plays, then it could be just component or input on wrong selection
Oct 17, 2010 | RCA 32V550T 32" TV
Black box showing up in center of tv
your closed caption feature is turn on and in the text mode. either turn off the closed captions or change it from text to cc1
Jan 08, 2009 | Toshiba 32A33 32" TV
RCA F32450 32" TV: suddenly shut off wont turn on
Followed Terryfic's solution. I am a DIYer and managed to order the part, desolder the old one and solder in the new one. However, when I turned it back on I got a black screen with sound. Hmmm, saw the adjustment screws but was hesitant. Ended up turning about 10 degrees one way and presto chango... Saved a $1200 upgrade to HD for a $30 part! Thanks
Oct 31, 2007 | RCA F32450 32" TV
RCA 32V420T 32" TV
reset by unplugging AC cord for few minutes, a few hours,or overnight,if needed.Let me know if that does not work.T.
Oct 09, 2007 | RCA 32V420T 32" TV
Sony Trinitron KV-32S40 32" TV problem
This is a simple and common problem. The solder joints on the vertical output IC have cracked loose. I actually did a housecall on the exact same set with the exact same symptoms this morning! A good tech will resolder the pins of the vertical output IC and all other major solder joints on the main board and the set will play fine.
Sep 30, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Half black screen on projection tv
Sounds like the vertical area like Output, but I would look for bad caps first and resistors. In this area
Sep 14, 2007 | Televison & Video
RCA 32V420T (32 inch)
I think that vertical deplection IC of you tv set is shorted. Please check also the YOKE of the unit, its maybe grounded.
Sep 10, 2007 | RCA 32V420T 32" TV
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
