SOURCE: D-Link DI-624 wireless router is not working after firmware upgrade try
Try to unplug the router and hold in reset button for 30 seconds see if that works, you probably did that already, But if you can get your computer to respond you should be able to open software Bios. and do your firmware update from there. If not I believe a hard reset is with the router plugged in and holding reset button for 30 seconds, I don't know I sure hope that resets it for you. Thanks take care
SOURCE: D-link DI-624
Hello, 192.168.0.1 is usually the default address. If the router is connect to the PC or Laptop with a straight through ethernet cable, browser should connect. The only reason is the default has been changed. The easiest thing would be to set the router back to default. Push reset on back of router for 5-10 seconds. Then try to access with default address. Username is "admin" leave password blank. Hope this helps.
SOURCE: D-Link AirPlus Xtreme G DI-624 - Setting Wireless Key
You don't need any software, no. All you need to do is login to the router (usually 192.168.2.1 or 192.168.1.1 for D-link) and configure the wireless security (including the key)).
SOURCE: what is the latest upgrade Firmware
Hi, You need to make sure you use a hard-wired connection to upgrade your router and the latest firmware can be found at http://support.dlink.com/products/view.asp?productid=DI%2D624%5FrevC#firm (This is for North American users only! If you do not reside in North America - DO NOT USE THIS).
SOURCE: where can I get a free d-link DI-624 installer online?
There are multiple revisions of the DI-624,
each with version specific drivers, firmware, installation guides, and
other resources. Please use the descriptions below to
identify your revision.
The links will take you to the drivers and install guides.
Note: The revision is located on the label on the bottom of the device next to H/W
The DI-624 Rev. A has 2 antennas.
<img src=http://support.dlink.com/prod_img/revisions/DI-624v.jpg>
Driver here: http://support.dlink.com/products/view.asp?productid=DI-624
The DI-624 Rev. B has 2 antennas.
<img src=http://support.dlink.com/prod_img/revisions/DI-624_revBv.jpg>
Driver here: http://support.dlink.com/products/view.asp?productid=DI%2D624%5FrevB
The DI-624 Rev. C has only 1 antenna.
<img src=http://support.dlink.com/prod_img/revisions/DI-624_revCv.jpg>
Driver here: http://support.dlink.com/products/view.asp?productid=DI-624_revC
