Well it is a drain blockage code. Check the pipe. I had a blockage caused by the stalk off an apple and an accumulation of lint!
Miele Dishwasher Error Code = Fault code F11 (Drainage) = Water not draining away. Cause Of Error/Fault Code = Filter combination in the cabinet is blocked.Jun 30, 2016
I understand you are receiving an error code "1" on your Electrolux dishwasher. Error code "1" is a leak detector. This does not necessarily mean that there is a leak. This could be a false code. I suggest resetting your appliance, by either unplugging it or shutting the power off at the circuit breaker, for 20-30 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
Getting an Error Code 2 on your dishwasher, means there is something going on with the turbidity sensor. This is the sensor that determines how dirty the water is which in essence determines how long the cycle will run.
What you can try to do is to reset the appliance for 30 minutes. You will do this by cutting the power at the circuit breaker and leaving it off for no less than 30 minutes. Try running the cycle again and if you are still receiving the Error Code 2, I would recommend contacting the manufacturer for further assistance.
Good Morning sewblessed - Generally, error code E06 means
that when the unit is in the dry cycle, the control does not receive the proper
speed feedback from the lower fan. One of the best ways to determine if this is
a false error code is to reset the power to the appliance by either unplugging
it or flipping off the breaker for about 30 seconds. If the error code
persists, then more than likely the lower fan will need replacing and I would
recommend connecting with an experienced appliance repair tech to assist
further.
305 Booster content is insufficient for rinsing
See error code 301, booster tank level sensor defective/disconnected, water inlet strainer is soiled, booster tank vent is clogged, anti siphen flap.
301 Level 1 not reached when filling (number of cycles exceeded)
Booster pump output low/defective, rinse nozzles clogged, wash tank level sensor soiled, moisture in sensor tube, hose kinked or not water tight.
The light cover on the side is loose causing it to flood remove the side and tighten the light cover the tilt the dishwasher to get water out of the float tray. let the dishwasher dry out and you should be grand
