When I auto-clean the oven, smoke comes out of the vent below the control panel and stains the white panel face. If I want to clean the panel face, it appeares that I have to remove the side covers and then the front panel. How do I remove the side covers and the panel face? It's Magic Chef model 3468 V V V purchased January 1996.
Where can I buy a repair manual for this model?
SOURCE: magic chef electric range model 38HK-6TXW
MAGIC CHEF
Range/Stove/Oven Fault Codes
Failure
Code
Condition
Check/Repair
F1
1. Watchdog on board
2. Touch membrane defective
To determine which component is at fault, disconnect ribbon strip. If NO fault code, replace membrane, otherwise replace board
F2
Oven too hot
Check oven temperature sensor
F3 F4
Open or shorted oven temperature sensor
Replace
F5
Hardware and watchdog circuits disagree
Replace clock assembly (also called the ERC)
F6
Missing AC signal
F7
Function key shorted
Replace touch pad
F8
Analog/Digital converter
F9
Door latch
Check door lock circuit
F10
Function key stuck
Replace touch pad F6 means no ac signal and will need to replace the oven control.
SOURCE: How do you light the oven pilot on Magic Chef 31000PAW
open the oven. take out the racks and push on the button plan toward the back and left it out of the oven.
you will see a small orfix appromiate middle of the fire ring. light a match to it. put eveything back.
you in business.
SOURCE: REAR RIGHT AND LEFT FRONTBURNER WON'T IGNITE
The most common problem for gas surface burners is that they get gas but don't light. This is generally caused by dirt or grease splatters on the burner itself. Residential-grade range/stove burners are round and have small holes around their perimeter to allow gas to flow out and create a round flame. The gas coming from these holes is often ignited by a small vertical row of holes on the side of the burner. If these vertical holes are clogged or obstructed, the gas can't ignite.
The solution is to clean the burners thoroughly. Use a toothpick to clear the small vertical holes, then allow the burner to dry completely and try lighting it again. If it doesn't light immediately, repeat the procedure
SOURCE: ovens not lighting magic chef
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
wwt
Below are instructions on how to take your oven door apart to
remove any stains that may be caught down in the door vents.
Tools needed: good Phillips head screwdriver or small quad bit
driver.
A. Open Door remove 2 screws and washers on door lining at door hinge area.
B. With door in broil stop position lift door assembly off
hinges.
C. Lay door on table, position so that handle hangs freely over
edge of table
D. Remove 2 screws and washers that secure handle to lining
assembly.
E. Remove 8 screws that attach textured steel door wrapper trim
to lining assembly 3 at top, 3 at bottom, 1 on each side
F. Lift door lining up and out of wrapper trim assembly.
G. Lay lining assembly on table with wool shield/inner part of
lining facing up.
H. Remove 2 glass clamps via 2 screws per clamp. These clamps
attach innermost clear glass to wool shield.
I. Lift out center clear glass from wool shield, this glass
just lays onto the wool shield and is held in place by the glass/ clamps in
item
H.
J. Clean each glass with appropriate cleaner, Windex, bon ami, fantastic, etc
K. One glass that remains in door lining assembly can at this
time be cleaned without further disassembly the lining assembly.
L. Reassemble in reverse order.
