When I first turn on the TV everything is clear after about 10 minutes the screen will start changing colors the whole screen will turn red then yellow or green then clear it will keep changing every few minutes, you can still see the picture it just turns colors. If I turn off the TV for a while it will clear up again and last another 10 to 30 minutes before it starts again. It looks like the color is on the outside kind of transparant you can even make out colors in the picture behind the other colors.
Lightning destroys everything it touches. When a modern electronic device gets a shock from lightning, you can bet things you never thought of are damaged. Make an insurance claim and replace the whole set.
T'Con board fault. Check and replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD screen are similar, irrespective of its brand and screen size.
This tv have a power supply board is the causes and the problems.Ur tv power supply board finally gave out and not supply the right voltages to the tv system anymore.That the board,where the tv power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
my mitsubishi 73" set is 4+ years old. all of a sudden the color is all wrong. after a couple of minutes of clear picture the colors change--blue is green and red is yellow. a little while later everything has a red tint to it and there is a line going down the center of the screen. to the left the picture is still relatively sharp, but the right hand side is terrible. I'm hoping this is just the lamp.
mi tv turns on but only in color blue,next tv turn off red light apear one time and second time flash twice,whit mi remote control power on tv turs on ,then whit mi remote control send change chanes or any other funcion the tv turns off,letme now if you solve yor problem ,and i apreciate if you have some tips for me,thank.
Yes you have a problem in the red crt driver board. Most likely the driver transistor is failing. This is a component level repair, so if you have no experience with TV repair, play it safe and call in a trained tech to assist you in this matter. Good Luck
