SOURCE: my cx 6400 prints blank pages why
WON'T PRINT CX400 SAYS IT HAS AN ERROR WHEN ASKED TO PRINT
SOURCE: prints extra blank page for every one page of printed material
hi,
try this
> unplug the usb cable from the computer
> click on "start--> control panel--> printers and faxes"
> select the printer icon associated with your printer and delete it.
> now plug the usb cable to the printer
> wait for few minutes while all the drivers are installed.
thats it... now try to print... it should be resolved
thanks and regards
agnel
SOURCE: printing blank pages
I am working on the same problem. While you will not like the
answer here it is for the canon mf6530. What is causing it
is the shutter over the laser is failing to open. There for
it blocks all exposer. A temperary fix is to carefully lift the
shutter and tape it open using black electrical tape. Then
try a few prints you should have an image if this is your
issue as it is mine. I do not recommending running it in
this condition very long. When I find the final answer I
will attempt to post it.
SOURCE: Printer sends out extra page everytime I print
either your paper size settings need to be adjusted in the software, or your setup has included a seperator page.
SOURCE: C7200 prints blank page between each printed page
You need to have the disk and reinstall the printer delet all the printers and fax that you have and use the disk to reinstall it fixed my issue or use the HP online chat to help with the issue.
test
Printer prints blank pages on certain documents and will not print more than one copy without pressing online buttom.
The printer appears to be installed correctly, but will only print blank pages.
come out blank pages
blank pages
My printer is printing blank pages with black marks instead of pages sent to printer. It does not stop printing until out of paper.
Julie Rucker
[email protected]
