Turn off the
water valves which supply the water to washer hoses. Switch the hot and cold water supply hoses
and tighten. Turn the water valves back on and try to run a wash cycle using
cold. If hot water only is entering the wash tub the water supply is ok. If
this is the case you can unplug the washer and turn off the water valves. Remove
the washer back cover and follow the water connection for the hot water. The
water solenoid valve will have two electrical wires connected
to it. Interchange the hot water solenoid wires with the cold water solenoid connection.
Connect the water supply hoses hot to hot and cold to cold then plug the unit then
test the washer on the cold wash. If the problem persists it could be a water
hose restriction or the timer circuit could be defective. If you have hot water
at the normal pressure purchase a new hot water solenoid valve. With the electrical cord unplugged be sure to
restore the correct wire connections on the hot and cold water solenoid. To
replace the hot water solenoid remove the hose clamp and hose to replace the
old valve. Connect the unit to the water and electrical outlet. Turn on the
water and test the unit for leaks being careful not to touch any electrical and
moving parts. If all checks ok and the correct temperature work, unplug the unit
and reassemble.
