Press and hold start button for 4-5 seconds.Make sure that the start button has been fully pushed down or turned far enough to activate the dryer.
After that plug something else into the same outlet. If it works, you know you have power to the dryer. If it doesn’t work, you’ll need to check for any blown fuses or tripped circuit breakers.
If the power is there, you need to check door switch, thermal fuse, thermostats, and start switch to see if one of these is faulty.
Make sure that the control settings are appropriate, and that any buttons are fully depressed.
Good Luck and have a nice day.
SOURCE: we had to change the
Your polarity has to be right on these newer electronic models
L-1 Black to black L-2 Red to red
Tech Sheet
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
