Euro-Pro Shark GI490 Iron Logo
Posted on Jun 20, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Shark iron wont turn on
I was ironing and it just quit power went off lights went out on iron but it was still plugged in. it is shark steam iron model 1490 11 less than 6 months old
Anonymous
Level 3:
President:
  • Master 2,702 Answers
  • Posted on Jun 20, 2010
Anonymous
Master
Level 3:
President:
Answers
2702
Questions
Helped
909791
Points
7895
Take it back to were you got it from i think the regulator has just packed up
My shark steam iron is leaking when ironing
It is quite possible that this is a defect in the shark G1490F... I had the same problem and it was a crack in the water holding tank caused by tightening the two front screws (hidden) that hold the tank to the base... It seemed fine at first but after a full heating it developed a crack where it had been weakened when it was assembled... I suggest returning it or if warranty is up , throw it away and get something else..
3helpful
My Shark Iron leaks....
fill with water turn iron on max keep turning steam dial all the way to the right until you get to self clean hold iron horizontal and make sure you have a towel or something to catch water drips and debris coming out of iron let iron steam and spit water out until it stops on its own turn dial back to regular steam settings wipe residue off of the plate with a towel adjust temp settings back to normal
Wont heat as much and on steam setting it leaks
make sure you dont have the steam dial on self clean if it if is iron wont act right
1helpful
Stopped producing steam
Iron not heating up sufficiently to produce steam. Threw it out!
1helpful
SHARK STEAM STATION G6200 SUDDENLY STOPPED WORKING.
take it back to the store and tell them what has happend the only thing i can think of is that one of the wires has come loose within the cable
My G1490 Shark Iron will not heat up.
your heating coil probally went bad its alot cheaper tp just buy a new iron
6helpful
My husband threw away the opereating instructions for our iron.
SELF CLEANINGIt is important to “Self Clean” the iron at least every two weeksto remove scale, calcium, etc. The harder the water, the more often the iron should be self cleaned.1. Set the variable steam control dial to any steam position.2. Fill the water tank up to the “MAX” level.3. Stand the iron on its heel. Plug the iron into the electrical outlet.4.Press the electronic temperature control button until you get the “MAX” temperature setting on the display panel and wait until the iron heats up and temperature setting light stops flashing.5. Turn the variable steam control dial all the way to the right to the self-cleaning position and hold the iron horizontally over the sink (Fig. 8).6. Boiling water and steam will now be ejected from the holes in the soleplate. The impurities and scale are washed away with it. 7. Move the iron back and forth as this happens.8. If there is any water left in the water tank after the iron stops steaming, just empty the remaining water in a sink following the instructions for emptying the iron. 9.Turn the variable steam control dial to the “0” position when the water tank is empty.10.Place the iron back upright on its heel to cool down before storing.
Top Euro-Pro Irons Experts
NOEL
NOEL
ADMIN Andrew
ADMIN Andrew
Are you an Euro-Pro Iron Expert? Answer questions, earn points and help others
