Hi,various reasons might be responsible for the problem you are experiencing with your camera,but nevertheless,this solution will be very helpful;
Are you using alkaline batteries, or worse yet those "Super Heavy Duty" batteries? If so, then we've just discovered your problem. Alkaline and regular "super heavy duty" batteries just don't have the power for more than a few pics in a digital camera. Some may even have problems just powering startup of the camera. It doesn't matter if they're new, and right out of the package. Digital cameras for the most part should only be used with rechargeable NiMH batteries (if you still have your instruction manual, open it to the "batteries" section. Pretty sure you'll see a statement similar to what I've just said,
If those newfangled batteries didn't fix your camera,the next thing to check is that your batteries are actually making contact with the battery posts, and that these posts are clean. If not, bend the posts up/down a little, and maybe clean them with a little rubbing alcohol on a Q-tip.
The next thing to try is examine both the battery and flash card door. There's usually a little switch on both doors (note some SD card doors do not have this switch) that activates when the doors are closed. If they don't, the camera won't start to prevent damage to the flash card or camera startup sequence. For most cameras its usually a little piece of plastic on the door that pushes in on a pin switch when the door is closed. Closely examine both doors to try to identify these switches. A lot of times that little plastic nib wears down or breaks off, but can easily be jury rigged with a small glued-on replacement.
Hope this was helpful.
Thanks and take care
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
