Emerson MW8102SS 1100 Watts Microwave Oven Logo
Posted on Jun 20, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Paint inside microwave oven bottom is peeling
Paint inside microwave oven is peeling
Chuck
Level 2:
Sergeant:
  • Expert 228 Answers
  • Posted on Jun 20, 2010
 Chuck
Expert
Level 2:
Sergeant:
Answers
228
Questions
0
Helped
79000
Points
573
The oven cavity will probably start to rust where the paint is gone. If you're up to it, sand it and paint it with a color that matches the interior color. Other then colors, there is nothing special about paint inside a microwave.
1helpful
Danby microwave ovens
Yes it is a certain danger, DO NOT USE your microwave until this has been repaired. You should be able to get specialist paint and kit from your local hardware store. Here's a handy kit I found online:
Microwave Oven painted lining repair kit MSC TOUCHUPKIT
1helpful
Paint is peeling off how can I fix it and do you know if its dangerous
I wouldn't advise trying to fix it and it's not dangerous. When heating food it causes condensation on the inside of the oven which pools at the bottom and causes rust and paint peel.
7helpful
Inside of microwave top peeling and blistering
If it's paint peeling, then once that paint is gone, rust will set in, which can cause arcing and disintegration of the chassis, when ruins the oven.
This peeling is usually the result of excess moisture accumulating in the oven due to blocked air vents or poor fan circulation.
Once those two issues have been ruled out or dealt with, then always be sure to dry out or leave the microwave open after use.
The peeling paint will need to be removed, then the area should be sanded.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
We're
happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
1helpful
White bottom panel inside the microwave is peeling in two spots. What can be done if anything?
affected area would need to be sanded and re-painted with microwave paint. repairclinic.com sells the paint
2helpful
2answers
The paint has started to peel off inside my microwave!
NO. The insides are baked on powder coat. If you paint it, you might as well throw it away. The paint can catch fire, even after it is dry.
Paint coming off inside microwave oven
HELLO' WITH IT BEING INSIDE A MICROWAVE I'LD ALSO BE WORRIED ABOUT RADIATION POISON SOUNDS LIKE ITS TIME FOR A NEW MICROWAVE
Paint damaged in side microwave oven
1) How is the cavity damaged? Is it just peeling paint, or is it rust? If it's rust then the microwave could be dangerous.
2) The antenna cap usually has a small hole in the centre, but if there are any other holes in it the magnetron itself could be damaged, and holes caused by the magnetrin arcing.
4helpful
Inside finish is peeling off
No, if the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Otherwise, you can have rust and arcing, which can be messy.
3helpful
Peeling paint
Here is a link to buy the paint.
If the microwave is not creating a spark inside when in use, It's OK to use.
13helpful
3answers
Peeling paint
You need to thoroughly clean it, then sand it smooth to removew all the loose paint.
Once it's squeaky clean and dry, you can apply high-temperature appliance paint, which is available in brush-on or spray-on form at big box stores like Wal-Mart, home improvement centers like Lowe's and appliance parts stores.
Top Emerson Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
